Question about AGA ACMP-LP-AUB Companion Cooker LP
The aga whistles and have to turnit down to stop it
Toyota 4runner problems
check for an over heating situation with the motor as what you say indicates engine over heating.
Jan 23, 2014 | Cars & Trucks
Why does my Big Buddy Mr. Heater make a whistling or humming noise?
mr heater makes a whistling sound as gas escapes around the gasket of the ceramic heating elements, that is ,all around the outside edges of the ceramic heating elements.
You can find out exactly where the gas leak is , by pressing down on the outside edges of the ceramic elements with a big, long
slotted (flat bladed) screwdriver while mr heater is running and hot.
The screwdriver needs to be long enough so that you dont burn your hands [the longer & bigger the screwdriver, the better] & it does not hurt to wear heavy gloves too, because it gets very hot, very fast in front of mr heater.
The thicker the blade of the screwdriver is, the less chance of damaging the ceramic heating element because a thick bladed screwdriver will not concentrate all the pressure in just 1 tiny point.
You are not trying to crack the ceramic with a wood chisel.
Dont press down so hard that you break the ceramic heating element, start by pressing down gently and gradually increasing pressure until you notice a change in the whistle or sparks comming out of the heating element as loose carbon deposits
come out of the heating element and burn in the propaine flame.
When you press down on one edge ,the other opposite edge may come up slightly, resulting in loose carbon deposits escaping and burning as sparks.
also, you may not be pressing at the spot where the gas whistling is comming from and will need to move the screwdriver flat blade around the edges, here & there, to test for the effect of pressing down.
When you press down on the outside edge where the diamonds stop, while mr heater is whisteling, the whisteling will stop & mr heater will run quite. Sometimes, just pushing down with the screwdriver will stop the whisteling ,for a while,and maybe a good long while.
The big pain in the **** solution is to put a new gasket around the
ceramic heating elements, but there is no guarantee that the new gasket will not whistle.
Its a big ,nasty job, which I would rather not do--so I just push down with the screwdriver, to temporarly stop the whisteling, I guess it depends on how much the whisteling annoys you, as to if you want to go thru all the effort & expense of changing out the gaskets, without knowing if it will still whistle when you are done.
Im just a diy guy that has 3 big buddys I keep going for 4 yrs now.
I took one apart to look 4 the cause of the gas whistling, and then put it back together. Funny,it stopped whisteling & that was 3 yrs ago. I didnt put in any new parts.
It may help ,a lot ,to increase the pressure with which the Mr heater ceramic is pressed down against the gasket material.
This is accomplished by a heavy stainless steel wire that runs behind the ceramic heater element and goes through sheet metal
tabs on each side of the ceramic mounting frame.
You can bend the wire and the tabs,but only a little bit, and be very careful not to break the tabs because the tabs are not repairable, to increase the downwards pressure of the ceramic element against the gasket material. This may stop the gas whisteling--
its a try & see thing, a finicky adjustment, that sometimes works
& sometimes does not and sometimes, after a week or two, the ceramic might reseat itself against the gasket material and the whistling stop. Mine did stop whistling, but not until a couple of months after i did the job, due ,i think to reseating of the cermic against the gasket material. its try & see thing.
also ,a gas tank that has higher than average gas pressure may start gas whistling up but the whistling will stop after you have burned up the higher pressure of the propaine.
Jan 06, 2013 | Mr. Heater Big Buddy Heater
96 ford prob gt whistling very loudly when accelerated
IAC idle air control valve is not working. Let me know how you make out?
Jun 20, 2012 | 1996 Ford Probe
Aga not lighting
you have an electric head on you BM valve if you turn off the power the valve will shut off if you want it to work with no power i.e. in a power cut you push the lever on the top of the electric head to the left and behind the stop so it doesnt return and the bm valve will be on manual
Dec 03, 2009 | AGA Kitchen Ranges
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
Apr 18, 2009 | GE Refrigerators
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
When is turn off the swıcht rpm indicator is not comıng zero..
Battery condition? Make sure battery connections are clean and tight this is a very common problem.
Mar 12, 2009 | 2004 BMW F 650 GS Dakar
Isuzu Rodeo 1995
as for the whistling one of the vaccum hoses is down check the actuator hoses and you wont get no whistling and as for the temprature you gotta be more specific
Oct 30, 2008 | 1995 Isuzu Pickup
AGA ACMP-LP-AUB Companion Cooker LP Logo
62 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
