<!-- from fixya rte -->What is the amps from the power supply? - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 22,107 Answers
Make and model is required!
Posted on Nov 22, 2014
Looking for schematics of ATX200-3516 ASTEC power supply. When i plug in a dc motor i have a peak of current firstly more than 6 Amps (6 amps is max rating at 12 Volts in such supply). So It shut the...
If your power supply is rated 6 AMPS and your motor is rated 14 amps peek, then when that motor starts it will draw the 14 AMPS, That will trip the power supply right then and there. After it runs a few seconds the AMPS will drop about ½ that, but still 7 AMPS is more then the power supply is rated, so you will need a different power supply.
Aug 08, 2011 | Astec (ATX200-3516) (ATX2003516) Power...
Morning, My Panasonic Viera TH-42PZ70B TV will not start up the red led is flash 7 times.
Either there is problem in your power supply or main board. There are many SMPS on the power supply board. First check the voltages coming out of the power supply & supplying to the main board. The voltages are printed on the power supply board. The top one is power supply & bottom one is main board.
sonsunny
Jun 17, 2011 | Panasonic Televison & Video
Hi, I want to repair BEHRINGER PMP3000power supply and I need the pinout diagram. Where I can find it?..
Those are a tough supply to fix. There are two power supplies on the board. A small switching one first starts and then when the input caps are charged a relay shorts out two large limiting resistors. Then the main power supply starts to generate the +/- used by the power amps.
When overcurrent is sensed, the supply shuts down... that is IF parts have not blown. Arcing within the power amp takes these out... the rear-most power amp arcs near the heatsink and wipes out parts there and sometimes in the power supply.
You cannot run this supply without a load on the small ofline switching supply that generates most of the smaller voltages. WARNING there are no bleeders on the capacitors on the big supply. If you don't bleed them and try to connect one of the power amps, you will get a NICE arc.
HINT: put a series light bulb like 100 Watts in series with the power input... saves fuses, the limiting resistors, transistors, etc.
Disconnect the audio line coaxes to the power amp and prop the face still connected to the supply to work on it.
The first thing is to weed out shorted transistors in the main supply (leave them out) and verify that the small supply is operating. If it is not, then likely the two sand coated limiting resistors have been blown... this is just a start on a typical repair of this.
Dec 29, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
Image source 50 code E64
E064 Error code details Power supply voltage error (high-voltage error)
0000 The presence of a high-voltage error is communicated by the composite power supply PCB.
(The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Main cause
 The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
 Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
 YES: Clean the contact, and set it once again.
2. Wiring
 Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
 a. DC controller PCB (J301) <-> composite power supply PCB (J136)
 b. composite power supply PCB (J130-7) <-> primary charging roller contact
 c. composite power supply PCB (J130-1) <-> developing assembly contact
 d. composite power supply PCB (FT133) <-> transfer roller contact
 NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
 Try replacing the composite power supply PCB. Is the problem corrected?
 YES: Yes.
 NO: Replace the DC controller PCB. pls rate for my good deed!!!!!!!!Good Luck
Sep 21, 2009 | Office Equipment & Supplies
Describe your Black &amp;amp; Decker Power To
No. You will need typically 35-40 watts for a LCD monitor. 20 watt may not even run DVD's on your laptop. Look for something 80 watt or so.
Jul 07, 2009 | Black & Decker Power To Go Cordless AC/USB...
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
2 yr old toshiba satellite laptop. Original power adapter stopped working. Replaced with a Targus I got at Walmart. Was wondering if this could cause problems. Thank you
As long as the output voltage from the power supply is the same as what your laptop needs your good to go, but, also check the output "amps" you need the amps rating to be the same or more on the power supply. The laptop will only draw the amps it needs so if the power supply amps rating is higher no problem, but if the power supply amps rating is lower it could cause the power supply to over heat and maybe die on you.
If you are unsure please check with someone familiar with electrical ratings.
Oct 19, 2008 | Computers & Internet
Regulated dc power supply
If it is fused at 10 amps, then any power supply 8 amps or greater should be adequate.
Nov 08, 2007 | GE 35840GC3 2-Way Radio
717 people viewed this question
 Grubhead
Grubhead
