Question about Honda Garden
My 2600 psi power washer commercial Excell with Honda engine is not getting fuel. Where is the main jet located.
I have cleaned everything.
    Top Expert:
  • Honda Master
  • 23,154 Answers
If there is no fuel coming out of the fuel pipe, check for a blockage
Posted on Nov 22, 2014
mrrichardlbo
  • 59 Answers
SOURCE: pink vinyl tube under carburetor has fuel-smelling drip
no look to see if the clamp it on good it may have a pin hole in it best thing to do is relace it any auto store will have it...Good Luck
Posted on Aug 16, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Posted on Sep 03, 2010
  • 26 Answers
SOURCE: Hello- what is the oil
oil capacity is 20 oz. 10w-30
Posted on Jul 26, 2011
Excell 2600 psi won't rev High when I pull the trigger
clean out the nozzle jet
replace the pressure regulator
Aug 06, 2016 | Garden
Why does my Honda 3000 PSI (2.4 GPM) pressure shut off when I push the choke to the open position? Doesn't matter if engine is cold or hot.
Your choke controls the mixture of fuel and air. An engine will run rich if it has a restriction to air flow. Try removing the air cleaner, if after this you can turn off the chock you have a dirty air cleaner.
Apr 12, 2015 | Honda Pressure Washer PSI 3000
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
I have a excell 2600 honda 5hp gc 160.It has not been used for over a year. I empted the old gas out & put in new gas. It will start but when I push the choke in it shuts off.
A couple of things....
Clean the air filter and make sure it is dry.
Check for any springs that have come off of the linkage.
With compressed air, blow out the carburetor.
Clean and clear out the fuel tube from the tank to the carb housing.
Be sure you have proper oil level.
Out of what you have said...it is something in the carburetor....probably needs a flushing with air.
Give it a try and post back!
Jan 19, 2010 | Honda Pressure Washer PSI 3000
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Jun 14, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
100 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
