Re:5500'The program shuts off as soon as I enter my fitness level, every time
Everything, changing batteries, etc
    Top Expert:
  • Computers & ... Master
  • 25,692 Answers
I don't recognise the laptop type. Please clarify.
Posted on Nov 22, 2014
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
Fit
hi there!
The program doesn't fit on computer screen because the resolution of computer screen is too low. could you right click on the desktop and change resolution of screen to higher. I guest your current is 800x600. Change it to higher will fix your problem.
( another way to change to enter button is using Tab key on the keyboard. Every time you hit Tab key, it will move to next button on the program.Try Tab and hit Enter on the keyboard.)
Hope this will help.
Jul 30, 2013 | Avanquest Fix-It Utilities 10...
I've a smart UPS 1000VA SU1000INET I've had new batteries fitted. I put on to charge everything seemed ok. Went back to it about 2 hours later to find the 6 middle lights flashing.
Hi Ian,
Time for a new unit. Some component on the board level is malfunctioning.
If you need UPS, Surge, or Power Related help contact:
Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
Apr 15, 2012 | APC Computers & Internet
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
My 1995 Plymouth Neon will run fine as long as it's cool. But as soon as the temp outside comes up, it shuts off & will restart within a few minutes. If you do this very many times,, it just...
if car shuts off when hot outside, change thermostat and radiator pressure cap.-- heres more-car shuts off when tempurature of engine gets to normal. causes; low coolant, failing coolant temp. sensor, air in water pump. it takes 10-15 minutes to reach normal range. hope this helps! good-day!
Sep 01, 2011 | 1996 Plymouth Neon
My 2002 alero makes a click click sound when in the ON Position & will not start
Check for a good/clean connection on your battery terminals. If they have crud on them, disconnect the terminals & clean everything off with a wire brush & if possible, you can use some baking soda or even a Coke to help get the crud off. Rinse everything off & let it dry a bit (check the water level in the battery too - if the cells dry out, that'll kill it). Hook the connections back up good & tight. Then try to start the car - if that's not it. Get a jump, then go to Auto Zone, O'Reilley's, etc and get the battery & the starter checked. I'm betting it's either a poor connection, bad battery or your starter is going out. Start with your connections - that's the easy fix. Good Luck.
Jul 10, 2011 | Oldsmobile Alero Cars & Trucks
Why want my 1995 sedan deville cadillac start.
Also think about getting the alternator checked (Autozone, O'reilly's or even Pep Boys can do that for free). If the alternator is out or going out, it's not charging your battery - that means everything electrical in your car is now trying to run directly off the battery & draining it (it doesn't take long - especially if the lights or A/C is on). If those check out ok, take it into a mechanic & have them run a diagnostic - you may have a relay out.
Jul 10, 2011 | 1995 Cadillac DeVille
Zoom level keeps changing
I had this same problem after I downloaded IE9. The zoom level kept reverting. I tried every solution I could find that was offered on this site. Nothing worked. I disabled Google toolbar and the problem is gone.
jon
Apr 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
