Question about LG Televison & Video
My LG 32lh7030 Won't start, keep's spinnin the red led around
Changing power cord, openning the set,(nothing burned inside), cleaned everything. Red led keeps spinning around and nothing happens
  • Joao Peixoto
    Joao Peixoto Nov 27, 2014
    Update: Yesterday, after leaving the lcd unplugged from ac since saturday, I went for a final test before taking it to the LG technical support, and without doing absolutely nothing to it, I plugged the ac cord on it and it started without showing any abnormalities and its running 100%. Now the question is, "Why did it happen?" and Why did the problem solved by itself? Thanks
    Top Expert:
  • LG Master
  • 75,452 Answers
Contact any service technician; or the authorized service centre for LG. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 22, 2014
Testimonial: "thx, I'll try that asp, then I'll post here the diagnostic they found."
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
freetek
  • 5568 Answers
SOURCE: tv will not power up
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Mar 30, 2009
  • 556 Answers
SOURCE: keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Posted on Aug 07, 2009
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
info33
  • 72 Answers
SOURCE: Lg 42ld450 is not turning on. It keeps flashing
The power board or power supply could be the likely cause of the problem. Have that checked out.
Posted on Jul 04, 2010
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Sound no pic opened the back up red light flashing on bord
The red led may just be either showing shutdown or may be normal.
Someone to start would have to check all voltages on power supply board inside the set (follow power cord to it)
If no picture or brightness if even one voltage (voltages usually marked at plug/s on power board) is missing or very low your problem is on that line.
Mar 17, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
LG 26LX1D. Has worked for 2 years. Recently moved but the day I left I was still watching the TV and then wrapped it in a thinks blanket for protection and placed it ontop of several winter coats for more...
It's possiable the powerboard is just not filling those cap's to capacity, this would explain why the green light does not come on, also what can be possiable is a relay in the power board that is not passing the 110v. I am uncertain of cause.. However 5days would drain the capictors to a point where the refilling process failed. I am just wondering if it got could in the structure? IF so how cold. Eletronics only can handle a certain temp.
I would say power board.
Feb 11, 2012 | Televison & Video
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
No power, red led doesn't light. Power cord is
Manufactureres usually keep their schematics to themselves however you may be able to contact them to purchase a new power supply.
Jan 23, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Televison & Video Logo
57 people viewed this question
Computer Repairing
Computer Repairing
