Question about Health & Beauty
Ny mobility scooter is making a lowed noise from
Ny mobility scooter is making a lowed noise from the gear box I whent off a kirb it cut out now a lowed noise from the back and it gos slower can anyone help please
    Top Expert:
  • Health & Beauty Master
  • 22,127 Answers
Possible damage to the axle or bodywork. I should have it checked out.
Posted on Nov 22, 2014
2 Suggested Answers
  • 177 Answers
SOURCE: Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Posted on Jun 25, 2010
Pride ultra making noises during ride
If you turn to the right and the speed of the clicking sound goes faster then your left wheel has the problem. The shaft key is a little loose and is shifting while running. If you turn to the right and the speed of the clicking sound goes slower then the right wheel has the problem. Sometimes a stick will become lodged underneath making contact with the wheel or rim making a clicking noise. These noises can drive me nuts. Scooter Doctor App
Jun 01, 2016 | Pride Health & Beauty
I have a pride go go elite traveler which has a knocking noise and gets slower and slower
hi,if the brake getting hot that means it not releasing fully,beware if you continue to use the scooter you may damage it further as you stressing the motor and controller unit...
I offer a free testing service and i'm able to fix a majority of brakes for low cost..
so what's happening here ?
Okay a voltage is applied to the brake allowing the motor to spin, the brake releases by powering a magnetic coil this in turn pulls the fiction plates away allowing the motor to spin...
Regards
Rob
www.gewizrepairs.co.uk
www.facebook.com/gewizrepairs
Jul 02, 2014 | Pride Health & Beauty
My rascal scooter was making a wining noise now it wont go
Hi, Firstly disconnect the batteries and let the scooter dry out,
1. Does the scooter now turn on ? once batteries have been reconnected.
2. The wining noise was coming from the rear ?, if so firstly check the wheels are okay can be turned around, now the noise was most likely coming from the motor or gearbox, can it turned round in free-wheel okay , this will prove that the gear is not jammed etc...
Please update me on the situation.
Regards
Dec 20, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My Pride Revo Mobility scooter needs a new gear box.
never said how old it is,cant give you a good answer without knowing.
Sep 13, 2012 | Pride Mobility Revo 3 Wheel Scooter
I've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Block the rear wheels up off the floor. Now put the sccoter in gear and let her rip! Is it real noisy? Did they replace the motor or the trans-axle on which th motor is appart of. If they replaced the entire assembly and its still making noise, thats what they sound like. Ive heard some of the scooters make a winning sound. Go to a place that sells this model and compare. My scooter is a Rascal 600t it makes some noise. It shouldn't be too noisy though. Its hard to tell from here.
Jul 12, 2012 | Electric Mobility Health & Beauty
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
Apr 16, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Needs a check up
Check the brushes in the motors to make sure they are not sticking or the brush caps are not loose. Also check all connections from joystick to controler box to motors. Also check battery connections are not loose. Get it serviced.
Oct 17, 2009 | Electric Mobility Shoprider Electric Power...
Health & Beauty Logo
80 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
