Question about Boating
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now the wind speed is fine but the direction dowsnt move although looking at the vane directly, it points as it should. I did a calibration and since then the unit wont give proper direction. Any advice anyone?
  • 3 Answers
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Posted on Nov 25, 2014
  • Boating Master
  • 696 Answers
Hi!
The only thing i could possibly add to sailsteve's answer would be to provide you with the link to your owner's manual.
-Steve
Is there such a thing as a reset for the Autohelm  - 1_12_2015_11_57_20_pm.jpg
Posted on Jan 11, 2015
2 Suggested Answers
  • 18 Answers
SOURCE: autohelm st50 how to calibrate??? wind instrument
I had one. Don't think you calibrate it. Reading is relative to it's mounting base. To change the direction reading, you would need to rotate the base.
Posted on Jun 18, 2009
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
Are there consumer complaints about the wind noise caused by the overhead luggage cross bars?
You won't know whether you'll have a problem with wind noise until you try it. I've driven 4 rack-equipped vehicles over the years. The only rack that made noise was the dealer-installed rack on an old vehicle, and that was ONLY during cold, misty weather (drizzle or very thick fog). What this shows is that wind noise can be a very finicky thing, as far as what causes it. That also means that if it occurs, you can probably come up with a trick to change the air flow which will stop it from happening (I've heard of tricks as simple as a spiral wrap of rope around the cross bar stopping wind noise, but I bet every situation is different). None of the other racks, including the boat rack for Subaru`s, which used 2x4s for the cross bars, made any noise that I could hear. In fact, the auxiliary rack for my current car (only used when needing extra width for two boats) also uses 2x4 cross bars, and it makes no noise.
I wouldn't use factory cross bars. There might be some good ones out there, but I haven't seen them. The general rule is to go with aftermarket bars, as well as the necessary bar-mounting hardware.
Some people love fold-down J-hooks, but since it only takes 30 seconds to remove them and about one minute to install them, why not just take them off, leaving bare cross bars? I take them off when not needed. I even take them off when parked by the river during a trip. After all, if I can remove both of them in 30 seconds using just my hands, so can a thief. Anyway, a folded-down J-hook is still a very bulky item to have up there compared to a bare cross bar.
Same goes for saddles. It takes only a moment to install or remove them, so if you want to keep air resistance to a minimum or not worry about the potential for wind noise, just drive with a bare rack when not carrying boats.
Jul 06, 2015 | 2015 Lexus RX 350
How to programeing wind speed st 70
Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Mar 07, 2014 | Raymarine ST70 WIND POD ONLY
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 | Boating
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
I have a windshield on a 2004 883xl harley. it is a high windshield but when i ride at speeds above 40mph it seems the wind is coming around the shield and pushing up against my chest and throat making it...
A windshield is supposed to direct the air up and over your head. In order to do this, the windshield must first be big enough. Too many people are opting to buy these small windscreens as opposed to full sized windshields. The wind screens are sufficient for the the sport bikes due to the way they are designed so that the rider lies down behind them. But, on a bike that is designed to be ridden in the upright postition, they don't work well. They may look cool but the don't keep the wind off of you.
Next, the windshield must be mounted at the correct angle. Usually, if the windshield is the proper design, this is not a problem as it's basically the same angle as the front end rake.
So, the only thing you can do to stop the problem you are having is to purchase a different windshield.
Jun 18, 2010 | 2004 Harley Davidson XL 883 Sportster
Autohelm mast Wind speed unit. Bottom bearing worn out. Can this be replaced, or where can I get a full replacement unit. Len
The part number for the lower pod is Q002. I am willing to bet that Raymarine will not have any more of these. The new ST60+ version will read faster than what the wind is actually.
May 15, 2010 | Boating
Autohelm st50 how to calibrate??? wind instrument
Jun 10, 2009 | Boating
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem
Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut).
The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP).
Raymarine have a forum you should join for more info and help.
Sep 05, 2017 | Raymarine Boating
Raymarine ST50
http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Oct 19, 2008 | Raymarine ST60 A22012-P GPS Receiver
Boating Logo
180 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
