Lg smart TV, will not display files on hard drive connected by USB. It recognises the device tho?
Please specify what you mean when you say "windows format" and "Mac format". If you mean that it recognizes .WMV files and not .MP4, then that is simply because the codecs includes in the television are only current up to the manufacture date. The good thing about Smart TVs is that you can update the firmware and this usually includes codec updates. Check that first, should be in the menu somewhere, look for "update". The other possibility is that it is an M4P file or M4U or .MOV, which is an Apple video or audio file. These have been encrypted to ensure playback on Apple devices ONLY. Thanks corporate America!! You can find hacks online to decrypt and convert them but I would just download an .AVI or .MP4 version of whatever it is you are trying to play and test whether the tv picks it up or not. Then you'll know if it's your device (USB), your tv, or protectionist Apple (most likely)
Posted on Nov 28, 2014
  • 57 Answers
It is not the proper usb standard by design, only made for thumb drives, read only
Posted on Nov 23, 2014
  • Gareth rodgers Nov 24, 2014
    It worked when it was in windows format.
    Now it's in Mac, it won't?
Beni S-P
  • 1006 Answers
SOURCE: usb device not recognised
First try this OPTION:
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
IF STILL NOT WORKING JUST BUY NEW EXTERNAL ( JUST EXTERNAL NOT HDD )
And rate me as fixya if u got help!
Posted on Dec 22, 2007
Beni S-P
  • 1006 Answers
SOURCE: Fell and now cannot access the drive
there can be 2 problems:
1) VIRUS INFECTED
2) DLL file is infected
Posted on May 26, 2008
SOURCE: EISA configuration
I believe that he EISA configured partition is where your computer manufacturers 'Restore System' data is kept so that you can't normally access it and mess it up. You seem to have gone to a lot of trouble to do work around that.
I would be interested to know if you can still restore your system now using the data that you transferred to a different partition?
Posted on Jun 09, 2008
SOURCE: USB Hard Drive Problems
Let me try
Posted on Sep 27, 2008
SOURCE: PC not recognising Iomega Prestige 320gb usb portable hard drive
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Posted on Mar 08, 2010
How to watch iTunes movies on LG smart TV without Apple TV?
Lg won't talk to your Mac, what I do is take a pc formatted USB stick and copy the movie to it and then plug it into a USB port on the tv. If the file is bigger than 4 gb you will need to write it to an ntfs formatted drive, the Mac doesn't speak that natively but there are free file systems for the Mac that do out on the internet.
Sep 22, 2017 | Apple Computers & Internet
My jvc smart tv wont recognise my new western digital hard drive
Digital tvs are good at this. I had to buy a digital converter box to pick up over the air channels with a usb port on it, to play mine, you can pick up one on amazon for about 30 bucks. Make sure it has usb streaming port before you buy it!
Jun 01, 2016 | Western Digital Computers & Internet
How to access the usb input from the tv screen?
  • To play USB media, you must first save your music or images onto a USB thumb drive.
  • Remember: The USB thumb drive must be formatted as FAT32.
  • Files on the USB thumb drive must end in a supported le extension (.mp3, .jpg, etc).
    • The player is not designed to play media from external hard drives or mp3 players.
To play your USB media:
  1. Connect your USB thumb drive to the USB port on the side of theTV.
  2. Highlight the Media app and press OK.The Media App launches.
  3. Highlight your USB device in the list and press OK.
  4. Highlight the type of media you wish to display: Music, Video or Photo. This info can be found in the manual here: http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Jan 30, 2016 | Vizio E320i-A0 32 Class LED Smart TV
LG LED 47" TV does not recognise USB stick
according to this site:
Looking for Answers about LG Electronics CM4530
USB:
USB drives listed as Version1.1 or 2.0 only, for MP3 files only.
Not sure it applies to your device.
Feb 26, 2015 | LG Televison & Video
I have a sum vision 2.5 sata to usb hard drive i want to record from my lg tv on to it but nothing is showing up please help
Think the USB has to be fat32 in order the tv recognises it.you are better off with USB stick or sd card for that sort of thing
Dec 04, 2014 | Computers & Internet
I have an external Toshiba hard drive 3tb. USB 3.0&2.0 There are movies on it( which play on Mac), but the lg smart TV will not show them. The tv recognised the device. Any ideas
The TV will not play Mac formatted files. You will have to play the files thought the Mac that would be connected to the TV as a source. It's a smart TV but not that smart....
Nov 22, 2014 | Computers & Internet
Seagate freeagent goflex 750 put some movies onto it no problem ,but my tv, or bluray usb doesnt recognise it .any ideas?
Welcome to Fixya. Can you pleae provide the make and model of the blueray device so that we can check if the file format of the blueray device is NTFS or FAT32. By default external hard drive is set to NTFS. A good example of this one is a PS3. Ps3 can only detect a hard drive that is a Fat32 fotmat so incase you connect a NTFS hard drive it wont detect it.
Thanks
Jul 16, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
My external HDD is no longer recognised by my PC. The usb port I tried works with other devices so that's not the reason. The curious thing is that when I connect the HDD to my TV I can view & play...
Plug it in, then on your desktop right click the My Computer icon, then click on Manage. From the window that opens click on Disk Management. In the right hand pane, you may then see your drive displayed. Right click in the lower right pane on your device and click on Explore. If it open the drive to show the files, you should be able to come out of all the windows and then access the drive normally.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Western Digital My Book Essential 1TB...
My Belkin Home Base F5L049 isn't recognising my external hard drives that have their own power supply. Seems to be working fine with USB powered hard drives. How do I get it to recognise my powered...
I am having similar problems with my HomeBase. I have 3 x 1Tb Seagate external USB2.0 NTFS drives (FreeAgent) connected. The aim is to have my digital TV, LG set-top box, Apple TV, PC and Laptop all access the files and capacity offered by the NAS option.
They work fine in 'single user network USB' mode, but are very flaky / non-existant in 'NAS, multi-user' mode. There are times when the HomeBase is restarted and recognises one or more of the drives in NAS mode, but mostly they are not recognised. On the back of the unit, you can see the LED next to the USB port leading to the drives initially stay lit, but then flashes for 10-15 seconds and then goes out.
As I want the hard disks available to multiple devices I need to use the NAS setting.
Did you try to set the drives into 'Network USB mode' rather than NAS mode. Does that help?
Did anyone have a solution to the problem? Unfortunately Belkin technical support have not been very useful yet...
Thanks
Mark
Dec 26, 2010 | Belkin Home Base WirelessN Access Point...
Computers & Internet Logo
David Payne
David Payne
