Question about Cycling
Dip light,how to change it?
How to change it?
    Top Expert:
  • 26,762 Answers
Make and model please
Posted on Nov 22, 2014
Head lights dont work on my 86 ford bronco II, new switch still not working
the main lights have dip and main switching
whats ever is up its the + side
so check the fuses and holders and wires and the dip main relays and main beem switchings
so...does the dip beam work if so its the relay or switch to dip main gone wrong
Dec 10, 2014 | Head Electrical Supplies
Oil light keeps coming on
I'd change the oil again.
Dec 10, 2011 | 2000 Plymouth Breeze
I accidentally changed Dip switches and light has power but no fan and no light ..have I blown a fuse ..thanks
Not likely blown fuse. Verify the correct dip switch settings... SOMETIMES the switches don't quite move completely so make sure they are completely one way or the other.
Jun 17, 2011 | Chauvet Kinta 311X DMX DJ Color Lighting...
My headlights won't turn on but my brights will in my 95 dodge ram 1500
when you say brights do you mean the sidelights or the dip lights ,if dip lights try changing the stalk switch or at least testing it with a meter to see if it has a feed out when moved backwards and forewards
Apr 30, 2011 | 1995 Dodge Ram
Light comes on all by itself
You are probably picking up some kind of radio interference that is causing the receiver to think a remote has sent it a signal. A possible solution to this issue is to change the frequency that the remote uses to communicate to the receiver to turn the fan or light on.
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
These directions are for the Hunter 27157 model.
Aug 12, 2010 | Hunter 27185 Remote Control
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
Jul 09, 2010 | Hunter 27185 Remote Control
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Gitting gti lights
The wiring is different, if your Golf had headlights with H4 bulbs then changing to high beam turns dip off. The GTi has separate dip and high lights, on high beam dip stays on (all 4 bulbs on).
Mar 20, 2009 | 1995 Volkswagen Golf
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
Remote Control Problem
I had this problem. One day everything worked. The next day the fan ran at 1 speed and the remote didn't turn on the light, change fan speed, nothing. I changed batteries on the remote - no good. As you should know, the dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. (They let you change radio frequency so that you don't control a similar fan down the hall as well as the one in the room that you intended to control.) Anyway, come to find out from the fan guy at Home Depot that sometime the dip switches on the fan "fall" out of place leaving the remote unable to talk to the fan. Sounded crazy, but sure enough one of the dip switches on the fan wasn't tightly in place. Once all the dip switches were tightly in place (with the fan dip switches matching the remote dip switches) everything ran fine. To change the dip switches on my fan that meant uninstalling the fan from the ceiling and taking the big top cover off to expose the dip switches.
My fan: Hampton Bay 54 In. Brushed Steel with Remote Model 55295
Dec 23, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
