Question about LG Washing Machines
LG frontloader keeps blowing fuse immediately
    Top Expert:
  • LG Master
  • 74,459 Answers
Short circuited component/s at its main power regulator circuit [SMPS]; inside. Contact any service technician. Electro help
Posted on Nov 22, 2014
2 Suggested Answers
mirzasaj
  • 15 Answers
SOURCE: Keeps blowing fuses
Try using higher Amps fuse.
Posted on Oct 13, 2014
Testimonial: "Will try this , thank you ."
Fuse keeps blowing immediately when switching on the treadmill, why does this keep happening?
A fuse is designed to prevent excessive current from flowing into a circuit. If the latter is not protected by the fuse, the excessive current can either cause some serious damage or the excessive current can overheat parts and perhaps result in a fire.
So, you are drawing too much current and that explains the small plume of smoke you experienced. If an electric motor runs slow because of excessive friction or load, it will use too much current, overheat and burn out the windings. Disconnect the motor and attempt to run the unit with the motor disencumbered. If the new fuse does not blow, then the problem is with the drive mechanism. If fuse blows, the problem is with the electronics and not the motor.
Aug 26, 2015 | Exercise & Fitness
Lg dryer keeps blowing thermal fuses we have checked the thermostat and the element all have continuity
The thermostats (outlet and on element case) can still allow the heat to go to high, restricted airflow will also cause them to go.
Jan 31, 2015 | LG DLE3777 Electric Dryer
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
EMC1 fuse keeps blowing immediately in 02 chevy express 3500LS 5.7L engine
That fuse powers the pink wire that runs to the coil, injectors, and pcm.
If the short isn't obvious, I disconnect everything I can from the wire and then put in a fresh fuse. I turn the key on and check the fuse. If it blows, I know it's something I haven't disconnected or the wire itself. If it doesn't blow, I start reconnecting things one at a time untl the fuse blows again.
Oct 02, 2017 | Cars & Trucks
Left tail light keep blowing fuse, at first in a coulpe days, now immediately..
there is a bad ground to the left tail light which is blowing the fuse. also it is possible that there might be corrosion which is providing high resistance which is blowing that fuse
Jan 13, 2011 | 1991 Saab 900
My fuses keep popping any ideas?
You have not supplied sufficient information so here is one possibility.
If you replace a fuse you must use one that is the correct amperage for the circuit.
Check your owner's manual for the correct amperage fuse for the circuit concerned and make doubly sure the correct one is installed.
If it is the correct amperage for the circuit please supply more information on the problem including which fuse keeps blowing:
1. Is the fuse popping immediately you replace it in the fuse panel and switch power to the circuit or only after a period of time of operating the vehicle? For example, if it is a lighting fuse, does the new fuse blow immediately you switch on the light concerned?
2. What is the function on the vehicle that has the power cut when the fuse blows?
3. Has there been any work carried out on any part of the electrical system or on electrical components of your vehicle prior to this problem arising? If so what was done?
Dec 05, 2009 | 1993 Mazda Protege
I have a 25 wat fuse in my power wire connected to my amp and i keep blowing it. should i put a bigger fuse in it?
Hello grabert205,
You do not say if the fuse blows immediately upon powering up or while the amplifier is operating. If it blows immediately, I'd check the power and ground.
If it is blowing the fuse while operating, I'd try a 30A and see if it holds. At maximum output of 100 watts times 4, the amplifier needs about 31 amps of current at 12.8V. So driving it hard could certainly blow a 25A fuse.
Hope this helps.
Jun 13, 2009 | DHD LCD-9444 Car Audio Amplifier
Fuse Keeps Blowing
Replace the lighter assembly, it is shorted, this is very common.
Nov 26, 2008 | 1991 Lexus LS 400
70a fuse in main box keeps blowing
dead short in wiring, maybe or fan moter is stuck or will not turn causing fuse to blow? can you smell wiring getting hot> or brushes shorting in fan moter.
Jun 25, 2008 | 1989 Honda Accord 4 Door
Washing Machines Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
