JVC AV-G14 HOW TO REPAIR ONELINE VERTICAL? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
You're asking this many times here. Are you sound in electronics? I don't think so.
Posted on Nov 22, 2014
JVC AV-G14 HOW TO REPAIR HAS STANDBY BLINGKING INDICATOR
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 22, 2014 | Televison & Video
JVC AV-G14 HOW TO REPAIR DEADSET?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
JVC AV-G14 HOW TO REPAIR AUTO OFF?
Will not always power up, just clicks and power light flashes. Vertical retrace lines at top 2" of screen. Keeps shrinking and goes completely away after about 5 minutes.
The JVC sets are well known for this type of problem, the tv has a vertical deflection issue needs a few small parts and a touch up on the vertical ic, causes the set to shutdown. I recommend a tv technician for the repair.
Jan 14, 2011 | JVC AV-27750 27" TV
THE VERTICAL AND HORIZONTAL COLORS DO NOT LINE UP.IT KIND OF LOOKS LIKE THE PICTURE IS IN 3D.
Thats caused by failed convergence ICs and feed resistors. You can get the JVC repair kit called the AV48WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with repair instructions.
Sep 12, 2010 | JVC AV-48WP74 48" Rear Projection...
Tv has no picture
try adjust screen in flyback, if you see a white line in bottom, the vertical ic have cold solder or is bad.
Apr 28, 2010 | JVC AV-27530 27" TV
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
No video on my JVC AV-30W475 30" flat screen.
It sounds like you have bad solder connections in the Vertical circuit or the horizontal circuit. The Vertical IC may need to be replaced if resoldering does not help.
You will need to call a good TV Tech for this repair.
Aug 09, 2009 | JVC AV-30W475 30" TV
Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Mar 21, 2009 | JVC AV-27D202 27" TV
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
