Hi, my TCL 42" model L40E3000F has a green screen. Sometimes on normal but mostly of the time turns green, we already remove all speakers and surrounds near it but still the problem exist. What should
We already remove all speakers and surrounds near it but still the problem exist. We also rest for a few days but still the same
    Top Expert:
  • Audio Player... Master
  • 74,136 Answers
A pure green screen is really a bad symptom. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 22, 2014
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
SOURCE: surround sound
1. have you got a surround sound recorded media ?
2. what input are you inputting ? digital or analogue LR
3. is auto surround on or off in the setup.?
4. is your dvd player dts and dolby digital ready?
answer me the questions ... in the process you will solve your problems.
regards
david174@gmail.com
Posted on Jan 31, 2008
  • 3 Answers
SOURCE: problem with speaker wires making contact in back of reciever on
Open up the receiver and check for poor solder connections @ the spkr junctions.
If you can solder, then solder a pin that is THICKER than the wire to it, the Bose wire is fairly thin and the spring clips don't clamp to heavily to thin stuff.
When you push the surrounds in you bottom them out in the connector. Having a thicker wire will eliminate the problem, use a piece of 12ga solid wire from house wiring. Make as many as you need and shrink tube all connections after soldering. Use White for + and Black for -.
Larry
Posted on Jan 29, 2009
Nomodo4u
  • 863 Answers
SOURCE: Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
Posted on Nov 01, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR-DE995 receiver and surround
Stereo source material can actually sound pretty interesting when various DSP surround modes are applied to them.
Or you could seek out some multichannel music. Look on eBay for Super Audio CD's, DTS-CD's, Dual-Disc or DVD-Audio. Though these formats died on the retail battlefield they still can be found and will demonstrate some awesome capabilities of your receiver. I have about 100 of them.
Posted on May 26, 2010
TV can not power up. Power button flashing, turns in green but no audio & video
I have a PDP 50 V8 plasma TCL tv
Turns green and back to red
Ive been told its the power board
Dec 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
When I first turn on the tv I get a degraded
Hi did you ever solve this problem? i have the exact same issue, i think its the main-y pcb but want to be sure. green pixels, slow refresh rate on screen, after 5mins the picture is normal till next time i turn it on.
May 25, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Green screen when changing channels. Works find most of the time but on occasion when changing channels with the remote a solid green screen comes over the entire screen. You can still get sound, and you...
Hi Betty, I have the same problem and am researching it so far I have read a variety of solutions not sure what to believe however here are a few of them. 1.Conections on a little white ribbon strip/cable inside the tv needs to be cleaned 2.Change your HDMI cable to a better one and or use standard RCA jacks 3.Unplugging the tv for 10 minutes then plugging it back in. 4. T-Con or video board going out 5. Factory reset? I hope someone has a solution fo this.
May 12, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hi I have a LG 42' plasma, but it wont turn
Hi Paul, This seems to be a common issue in most of the plasma flat screens. You are almost accurate in guessing the reason of trouble. The issue with the TV is mainly with the power board itself which happens in most models. Even though if you try replacing board level components you will finally end up in replacing the power board for sure. I managed to find a contact who can help with spare parts of most of the plasma models...i am posting it here for your reference. plasma TV parts-- Steve Hu: masterhu@yahoo.com .
Have a nice day!!!!
Sep 11, 2009 | Televison & Video
The green fades in and out
Its most likely caused by a bad solder joint on the Green CRT dive board which is located on the bootom of the green CRT ( Center CRT) which you can accesss by removing the front speaker panel then the small access pane behind the speaker panel. If the solder appears good the green CRT itself is most likely defective.
Nov 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Plasmasync 42 (2004)
the screen abnormality is not plasma burn. it sounds like u may have a shorted driver feeding the panel.
its repairable (might not b practicle)
May 01, 2008 | NEC PlasmaSync 42MP1 42 in. Television
Green picture
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
PT47QWX42 Projection TV Panasonic IS GREEN
Yes but sometimes you have to remove a cover behind the grille to get to them.
Sep 14, 2007 | Televison & Video
53 people viewed this question
 Grubhead
Grubhead
