Question about Dishwashers
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes. When I run a test cycle it also bleeps continously after about 5 minutes. The light flashes 4 times when I put it on. I've cleaned out the filer and there's no water in the dishwasher when it stops. Any ideas on what the problem is? Thanks
    Scholar:
    New Friend:
  • 80 Answers
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Posted on Nov 26, 2014
5 Suggested Answers
SOURCE: diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Posted on Nov 28, 2008
SOURCE: Dishwasher; Diplomat 8322. Set it to wash on any
Apparently there is a sensor above the normal water level where it drains. The water level rises above the sensor if the filter is full of gunge and the water cannot drain properly. The sensor is activated and stops the cycle. You have to remove the filter mesh, clean it, drain out the excess water (I did this with a turkey baster!) and replace the filter. Then everything works again!
Posted on Dec 18, 2009
  • 1417 Answers
SOURCE: Diplomat ADP 8322 - 11 Flashes. Will not go beyond
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Posted on Dec 24, 2010
  • 147 Answers
SOURCE: favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Posted on Aug 28, 2012
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
Will not start descaling
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Found the answer on another fixya post. Seems like about the same product.
http://www.fixya.com/support/t6123164-tassimo_red_light_stays
Apr 17, 2013 | Coffee Makers & Espresso Machines
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
Aug 27, 2012 | Bosch Dishwashers
Light flashing on mobility scooter
Hi check if the free wheel lever is in drive ...cheers
Dec 27, 2017 | Health & Beauty
Our water pressure was very low this morning due to a leak in our village. The dishwasher was on and it stopped with indicating bleep that it had finished its cycle. Now the start light flashes contin
try unplugging it and plugging it back in. it sounds like it didnt like the low pressure and went to a safety shutdown so it didnt run dry.
Dec 28, 2011 | Cars & Trucks
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
FDW 60 lights 4 and 5 flashin.Select programme,m/c then bleeps 4 times and then lights 4 and 5 flas together and nothing else happens!Any ideas please?
Control panel which is a bit sensitive might need re-booting. Mine did the same and had a mind of its own, doing what it wanted, lights flashing all over the place, not completing the wash etc etc.
Switch off the machine and unplug from the mains. Leave for 10 minutes.
Plug back in, switch the machine on to your required programme and if ,like me, you are lucky, your machine should work again. If it happens again in the future you know what to do. Failing that go to the Hotpoint website, find the customer service number and ask if there is anything else you can do yourself to solve the problem, before paying for a service call. They are really helpful
May 27, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
121 people viewed this question
Top Dishwashers Experts
