Question about Dishwashers
Hi there my indesit D63 won't work no more it just stop after a few minutes thanks
    Scholar:
    New Friend:
  • 80 Answers
Hello Asheek!
More details please!
"After a few minutes" means it starts, fills and begins the first rinse cycle, then stops. Water in the tub?
we need more info!
all the best.
Posted on Nov 26, 2014
  • 641 Answers
SOURCE: indesit D63
It sound that the problem is cause the water level switch (stuck in the "full" water position). The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear first any obstruction in the tube,In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on May 29, 2006
SOURCE: Leaking Indesit D63 dishwasher
try pushing down firmly on inner door panel at the bottom with door fully open. You will feel it starting to bend. This moves seal closer together when door shut. it worked well for mine.
Posted on Jul 15, 2008
SOURCE: Instruction Manual
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Jan 17, 2009
  • 236 Answers
SOURCE: Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Posted on Mar 16, 2009
  • 93 Answers
SOURCE: indesit D63 dishwasher dishes not getting clean
Check the rinse aid dispenser is set properly to release a small amount of rinse aid not full and not off but the first click should be fine,then under the bottom rack there are filters remove then and clean them regular,also remember to wash the dishes the same night that you use them ,leaving them over nite will result in the food going hard and you will need a hammer and chizel to remove some dried food,last please remember this is a dishwasher not a food disposal unit you need to rinse the dishes and scrap off loose food before washing
Posted on Dec 28, 2009
My Indesit D63 dishwasher is not cleaning things in the upper tray. There are no blockages in the spray arm but the rubber seal at the water inlet to the spray arm seems to be damaged. What should I do?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
34fes
Aug 19, 2010 | Indesit 24 in. D63 Free-standing...
Indesit D63 dishwasher dishes not getting clean
check that the arms top and bottom turn freely and are not blocked.also if you use tablets,then you do not need to use rinse aid in the door,the coating could be due to over rinse aid as the tablets have this in,if these are ok you may benifit from putting a good quality cleaner through if
May 05, 2009 | Indesit 24 in. D63 Free-standing...
Mar 16, 2009 | Indesit 24 in. D63 Free-standing...
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 21, 2008 | Indesit 24 in. D63 Free-standing...
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
Instruction Manual
Angie ,give it back,you are in for some serious head aches with this one.Sorry!
Apr 29, 2008 | Indesit 24 in. D63 Free-standing...
Bad designed and filled with mistakes, I cant lie to you and even reccomend a cure /fix for this.Sorry.
Nov 01, 2006 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
