Question about Coffee Makers & Espresso Machines
Why isn't the switch working and also only gives 1/2 a cup
    New Friend:
  • 4 Answers
Switches are often badly made. The button itself breaks and comes loose from the underside. When the bottom of the coffeemachine is removed after loosening some Phillips screws, one can easily remove the defective switch. Switches are not expensive, only a few dollars. Do not remove the wires from the defective switch before there is a new one. There are usually three
metal attachments for the wires, two in a silver colour and one in a yellow colour. It is important to attach the wires in exactly the same way as was at the defective switch. If the apparatus still doesn't work properly, put some water with some vinegar in the water tank and switch it on. The vinegar will make calcium in the apparatus disappear.
Posted on Nov 22, 2014
Hey my Pyle pro heavy metal distortion peddle isn't working. Everythings fine until I switch to distortion, than no sound comes from my amp. Any suggestions?
Check the switch to see if it is functional with an ohm meter. Also check length of plug and make sure it engages the jack securely as there are about 5 different lengths of 1/4 inch jack available. Are the effects powered by battery or through the amp, or on thier own power?
Jan 27, 2012 | Music
Amp isn't working but its all hooked up.
Hi tazmattiejoe,
  • The problem could be with the fuse , check if the fuse is proper and not blown up , if it's burnt then all you need to do is replace the fuse.
  • If it's not burnt up then you need to check the input device for the amp and if you can see power being reflected on the amp and it's properly switched on.
  • If the amp appears to be powered on but not working then you need to check if it's giving you an out put by changing the speakers , usually the input is the problem , when there is no input in the AMP or there is a mistake in connecting the input to the AMP there would be no output which could make us think that we have the problem in the AMP itself.
Therefore please check the inputs and out puts of the AMP and your CD/DVD player devices.
Hope that helps ...:) Let me know in case you require any further assistance , your feedback would be appreciated.
Sep 12, 2011 | Rockford Fosgate Audio Players & Recorders
If I want a medium cup of coffee, my coffee maker will give me 1/3 cup of coffee. I have tried cleaning it with a toothbrush and it is still not working.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 15, 2011 | Keurig Platinum B70 Coffee Maker
I've got a BT HomeHub which works fine with a 4-port Ethernet switch to give me a small home network of 1 Mac Pro, 1 Laptop and 1 printer. I have an older Netgear RO318 Router - with 8-ports. But when...
When you use the older Netgear RO318 Router, make sure you don't use the WAN/Internet port, only use the numbered switch ports of the router.
Jul 31, 2017 | NetGear RO318 Router
Hi my washes agitators is working but it won't do anything else. It's not spinning or rinsing the clothes. the knob isn't moving from cycle to cycle. Even if I manually put it on spin cycle it...
Hello, Thank You for using FixYa. I will be helping you today.Check the lid switch. Since you didnt give a model number it makes it hard to figure out but sounds like the lid switch
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Roper Washing Machines
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
