Question about Breville Hot Cup With Variable Dispenser 2lt Black
Breville vkj476 switch not working
Descaled and calcified it but switch still not working
Breville one cup filter kettle intermittently switches off before boiling . It will work if I keep the button depressed.
Oxidized or worn thermo-switch contacts.
Or, sometimes old age (kettle!:) or overheating can cause springy contacts to bend out of shape.
Get tech-minded person to open/inspect & renew as required.
Jan 19, 2017 | Breville Kitchen Appliances - Others
Vkj476 BReville hot cup with variable dispense. How do you change the filted britta filter
The Breville VKJ476 Hot Cup with Variable Dispenser does not require a filter so will not take a Brita filter.
Mar 21, 2013 | Breville Hot Cup With Variable Dispenser...
The on/off switch on my breville jk164 kettle has snapped off. Can it be repaired or a new switch put in?
Ring breville and ask if this part available,if so ask for price of part and repair costs .
Total it up, might be cheaper to buy a new one these days.
But do not repair yourself unless you are a competent electrical trades person.
Electricity is dangerous.
Sep 12, 2010 | Breville Kitchen Appliances - Others
How do I descale my Breville BKC600XL
Why not just fill the tank with vinegar & run it through as per the manufacturers instructions
Nov 07, 2009 | Breville BKC600XL Coffee Maker
Brand new breville juicer vfj005 cow design,it wont work,no book
In all juicers there are hidden interlock switches called interlocks for ur protection. Put all the parts properly, so that these switches sense them. then it should work.
zahid@uic.edu
Mar 05, 2009 | Breville Juicers
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Dualit espresso machine
lost my instructions for descaling my delonghi espresso machine
May 15, 2008 | Coffee Makers & Espresso Machines
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Breville Hot Cup With Variable Dispenser 2lt Black Logo
89 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
