Question about Zenith Televison & Video
My zenith DVD-11 duplicator is not booting up
    Top Expert:
  • Zenith Master
  • 74,468 Answers
Try a hard reset first. If it do not help you, the firmware to it is corrupted, and should be updated. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 22, 2014
Central locking problems kia venga
Time to replace the drives. How old is the unit?
Aug 27, 2014 | Duplicators Central 1 To 5 Targets Copy...
Can I record multiple dvd's after I have recorded from one vhs tape
You might consider after making the first if your computer is capable of making fast copies with it.
Apr 24, 2012 | Zenith XBR413 DVD Recorder
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
HOW DO I RESET MY1:11 TECH-COM DUPLICATOR?
how to reset 1-11 dvd techcom controller.
-when it is on aqnd the screen shows copy use the top arrow key to move to setup when in setup look for reset
May 06, 2011 | Primera Technology Bravo II DVD Duplicator...
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
What is the specification of this casing?
Introducing the NEW high-performance stand-alone CD/DVD duplicator systems. These duplicator systems are perfect for heavy production runs since there is no cooling period needed between runs. Beginners and advance users alike will find this system beneficial because of its ease of use speed accuracy and reliability. All it takes is a simple press of a button to get the duplication process started. Let the NEW high-performance stand-alone CD/DVD duplication systems serve as your solution for data backup music video duplications and much more!
  • Supports DVD+/-R DVD+/-RW DVD+/-R Dual Layer CD-R CD-RW blank media standards
  • Intelligent design automatically recognizes the source disc format
  • ?User friendly÷ controller utilizes familiar ?ESC÷ & ?ENT÷ keys with tactile feedback for easy navigation
  • System is upgradeable via firmware
  • Password protection modes prevent unauthorized usage
  • ?Dynamic÷ hard drive partition system saves HDD space by creating partitions according to the image size
  • Allows editing of image and hard drive partition file name
  • Fully stand-alone system - No computers needed!
Feb 10, 2011 | Sony 20X Burner/1 to 11, Black Casing...
The LCD screen for the duplicator go blank after power is switched on. The condition persist for a long time without any change/improvement. The unit cannot function.
before remove all the power plugs to all dvd drives and just let the controller plugged to power dose it works the display if yes try to connect one by one the drives and check the controller display till its ok and then may be one of the drive is defective.if still the same try changing the powersupply .
thanks
Dec 14, 2010 | Lite On Dupsonic 52X 1 to 11 CD Duplicator...
I have an old zenith ttl and an 11 both in good order but I need a new battery compartment cover for each of them. where can I get these parts ?
The only place to get them is by obtaining other complete models as spares donors. Spare parts are long discontinued, and as most Zeniths are completely without resale value and there are so few remaining users nobody is able to make a viable business out of breaking them for spares.
You don't have to pay for a donor, almost every Zenith and Praktica I've ever owned has come from my local FreeCycle and Freegle groups and the rest cost almost nothing from boot sales and charity/thrift shops.
Sep 14, 2010 | Zenith FS-122S 35mm SLR Camera
Is there a software update for lightscribe for lacie d2 blue ray burner, so that I can burn dvd titles on a disc?
When you say "burn dvd titles on a disc", do you mean to write (laser-etch) the name of the movie on the plastic disk? I am assuming that is what you mean. If not, please describe what you mean. . No, LaCie does not make a Blu-Ray LightScribe drive. This is a technology/hardware problem, not a software problem. . There are a small number of internal (I know you want external) Blu-Ray burners with Lightscribe hardware built in. Here is one: LG LightScribe GGW-H20L Blu-Ray DVD Sata Drive. . The Lightscribe website says no such media exists, even though the drives have been available since June of last year: http://lightscribe.com/products/index.aspx?id=106 Watch that site for info about the media. Once the media is available, you will be able to buy the external drive you want. . Here is a burner for only $4,400 (that is not a typo):http://www.meritline.com/sharkblu-lightscribe-8x-blu-ray-dvd-duplicator-1-11---p-35937.aspx . OK, it is a duplicator (burns up to 11 copies at once), hence the high price, but useless without the media. . BTW - It is a simple matter to buy an external USB2 or FW case and put an internal burner in that case to make an external drive. . --Dave
Feb 07, 2010 | LaCie d2 DVD-RW Burner
My Zenith Projection HD TV is displaying a series red lines
It probably needs the convergence circuit repaired by a qualified technician.
Sep 09, 2009 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
186 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
