Question about Garden
Do I have a bad battery if it boils when I try to crank
  • 1,169 Answers
More likely you have an overloaded starter drawing too much current or the starter is partially shorted.
Posted on Nov 22, 2014
Why is my battery boiling over 94 Telstar tx5 ghia
Your alternator is overcharging the battery VERY VERY BADLY. DO NOT drive that car until the voltage regulator is fixed!
Aug 11, 2014 | Cars & Trucks
I have 2000 Nissan Sentra w/1.8 engine. Check engine light, airbag light have come on and the battery has "boiled over". Had previously noticed smell of gasoline and engine smelled "hot". Checked
battery do boil, may be bad battery, check the volts 12,5 off to 14.7 max running, this car needs head gasket checked by looking to se if the coolant is too high in the bottle or too low
Jul 14, 2014 | 2000 Nissan Sentra
Hi would heated grips added to a honda transalp 600 cause the batterie to boil.thanks
No--but.... Heated grips will only put an added load on a battery, and that won't cause boiling of a battery. What WILL cause a battery to boil is overcharging or charging at too fast a rate. Now, then--when you add heated grips to the bike and you make a mistake somewhere in the wiring, you can affect the charging rate, and it's possible that a voltage regulator/charging system sees more current being drawn than it's used to and it's trying to replace that current as well as charge the battery, and it's feeding a higher voltage/current to the battery than was intended by the designers. You can check this out--put a voltmeter on the battery terminals, run the engine, and turn on your heated grips. A normal charging voltage for a vented lead acid battery should be about 13.8 to 14.4 volts; yours may go a little higher. If you're seeing a lot higher than 14.4 volts, you either have a defective voltage regulator or perhaps such a bad battery that it's screwing up your charging circuit.
May 07, 2014 | Honda XL 600 V Transalp Motorcycles
1999 honda odyssey won't turn over turn key nothing but lights work
no CRANK
the first test. is jumper cable cranks.
the lights only use 1/50th the current of a starter, and dont prove anything. (eg. bad batteries do run lights great, can prove.)
juimp start it,
good, yes. bad battery; battery dischanged,or bad charging system
or left on the lights. too long.
bad jump, this means the cranking system is bad.
bad crank.
1: cables from battery to starter, corroded.
2: bad cables. split open and green copper everywhere.
3: I hot wire the stater solenoid, if fails (good battery and cables )
then it is a bad starter, (i hit it with a hammer, and bam it cranks
great tick to get of of big time trouble , far off grid or? danger zones...
4: hot wire fails.
bad KEY line.
if key oine fails wiggle the A/T shift handle, cranks now?
try neutral cranking, (fresher contacts here, magic happens)
IF a stick shift car nows the time.....
ask how to hot wire or look here.
see test 1 here "hot wiring techniques"
http://www.fixkick.com/nocrank.html
I have M/T and park on hills and start by rolling starts.
i dont need a good battery, in my 1968 xxxxx (1/2 joking)
Jan 03, 2014 | Honda Odyssey Cars & Trucks
Saturn vue batter boiling blowing relays
what is an ignition relay, ?
did you blow fuses?
what fuels, and battery boiling (running or not?)
running boil , would be overcharging , a bad alternator, or wiring to same.
not running boiling is crazy levels of battery loads.
if in my shop, out comes the AMPclamp meter, to find out
who is sucking extreme currents. and why fuses are not blowing
did some (#@!$) put in over size fuses, inviting a nice fire?
but if you have no tools? what can you do.
little, hold wet finger in air?
you could disconnect things and stop the drain
put them back 1 at a time (days work) an find the part that sucks
too much juice.
send photo with finger pointing to said relay.
Oct 12, 2013 | Cars & Trucks
Bad boy mower
sounds like dirty carb get a rekit clean and boil the carb what i mean by boil go to auto store buy strong carb cleaner put the strip carb in it for two days take it out using compressed air we use 300 lbs blow every hole out in that carb if yu see tiny holes take a wire and poke the blow them out again put back to gether with other parts you boiled like the jet and down spout turn adjust ment screw out 4 turns that should get it started the run and adjust from there should run fine main thing dirty carb problem
Jul 10, 2013 | Garden
2007 cts ran hot. filled with antifreeze and now will not start. could it be the battery
did you run it to boiling point? if so and engine is spinning faster than normal you might have a blow gasket. crank engine with radiator full of water if it comes out of radiator when cranking gasket blown.
Aug 28, 2012 | 2007 Cadillac CTS 3.6L
I have a 1989 crown victoria and i have a small battery on it does it matter the size of the battery, because sometimes it starts and when i' am driving it for a while then shut it off and then try to...
The smaller battery could be over charging unless picked up by the voltage regulator, and heat is a slow killer. Cars require different amps to start. The main thing to look at is the Cold Cranking Amps. Which is the amps being put out at 0F or -18c. As for the antifreeze it wouldnt hurt to test is for freezing point and boiling point which are majour factors. The worst could be antifreeze in the oil.
Apr 20, 2010 | 1989 Ford Crown Victoria
2003 chevy impala overheated and now no power and wont restart
The overheating will not have anything to do with the lost of power for cranking or the lights not working. Try charging the Battery and start over.
May 11, 2009 | 2003 Chevrolet Impala
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
