Question about Casio Futurist Mens Vibrating Alarm Watch Black
Can't get Casio Futurist into vibrate mode since reoplacing the battery. The "VIB" area on the watch won't flash for me to adjust the setting. Am i doing something wrong or simply goin
Can't get Casio Futurist into vibrate mode since reoplacing the battery. The "VIB" area on the watch won't flash for me to adjust the setting. Am i doing something wrong or simply going mad?
  • Casio Master
  • 18,424 Answers
2 things you could have the back on wrong way or you've lost the small coil spring that touches the back plate of the watch that give you the vibration ,,
Posted on Nov 24, 2014
Nickstar19
  • 417 Answers
SOURCE: Casio WR200M Watch.
you need to pull the pin out the thing take turns on the watch don't come right out tho one like 1mm
Posted on Jul 05, 2008
SOURCE: Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Posted on Dec 11, 2008
SOURCE: can't set time and date on casio futurist 2001 watch
I returned the watch. It was a gift for someone and I had messed with it enough that I had to get another gift, They shouldn't make them so hard to use.
Posted on Dec 23, 2008
escapement
  • 2334 Answers
SOURCE: new battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Posted on Mar 28, 2009
  • 2501 Answers
SOURCE: Oh, one additional thing about my CASIO 'WAVE
You can align the analogue time with the digital time by pressing the mode button until you reach the hand setting position (HS) and then press one of the right hand buttons to change the hand position.
(Check out this with the instructions- it is all there!)
Posted on May 07, 2010
How do I set my watch?
This depends if you want to use the autoreceive mode or not. If you're within an area that you can pick up the signal, it should set itself automatically at 3AM, 4AM and 5AM. You can force it to try and calibrate to the broadcast signal by holding down the receive button while in the "normal" time mode. For best results, put it near a window that faces Colorado (assuming you're in the states) with the top of the watch facing the window.
To turn on or off the autoreceive mode:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Mode button twice so [ON/OFF] Auto is flashing. Press Receive to toggle the mode, then press Adjust twice to set.
If, for whatever reason, you're unable or don't want to use autoset, to manually set:
From the time mode, hold down the Adjust button until the watch beeps and your time zone is flashing at the bottom. Press the Adjust button again and 12H/24H will be flashing at the bottom. Press mode again and seconds will be flashing. Mode once more and the hours will be flashing. Use Time Memo/Receive to set it to what you want. Press mode again and minutes flash. Again, use Time Memo/Receive to set it to what you want. Repeat for year, month & day. Press Adjust to finish chaning the time.
Mar 18, 2011 | Casio GW330A G Shock Solar Atomic Watch
How do I set my Casio G-Shock watch?
Mar 16, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
Feb 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Setting Date & time
mcdevito75 here, generally you need operate 2 bittons to set your Casio watch, the MODE and SET buttons. Press the Mode button, you may have to hold it in for 2-3 seconds, see the display falshing, press MODe to go to each function, once at the function you want to adjust, press SET press MODE to move onto next function, once all functions are set, press MODE for steady display. If this fails, look for a small watch repair shop in your area for help setting up the watch.
Feb 11, 2011 | Casio Watches
How to set time on my Casio Lw-200 Kids watch Its a digital watch
Thank you for contacting FixYA.<br /> <div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none"> <li id="jsArticleStep1" itxtvisited="1"> Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.<br /></li></div> <li id="jsArticleStep2" itxtvisited="1"> 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.<br /></li> <li id="jsArticleStep3" itxtvisited="1"> 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.<br /></li> <li id="jsArticleStep4" itxtvisited="1"> 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.<br /></li> <li id="jsArticleStep5" itxtvisited="1"> 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.<br /></li> <li id="jsArticleStep6" itxtvisited="1"> 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.<br /></li> <br /> For more Casio info go to:<br /> http://www.casio.com/support/<br />Best regards.
Aug 24, 2010 | Casio LW200-1AV Wrist Watch
My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Jul 12, 2010 | Casio Watches
Cannot power on, new battery still cannot on
Check to make sure your battery is installed correctly. It may be in upside down.
Jun 26, 2010 | Casio Futurist Alarm Chronograph LCD...
Can't set time and date on casio futurist 2001 watch
Dec 22, 2008 | Casio Baby G Baby G Square Face Bg 2001...
Need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Mar 10, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio Futurist Mens Vibrating Alarm Watch Black Logo
112 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
