How do i program the remote with the wizarrd2 remoete
What are the codes for the wizard2 to get into channels?
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Nov 22, 2014
How do I program my haier remote to work for Mt Emerson. Tv
if it is not a programmable remote for all TVs then you cannot programme it. the programming is set up inside the remotes and you need the specific code for the specific TV , but only if the controller is for multi TV.
Oct 03, 2016 | Emerson Televison & Video
Trying to connect with Comcast using comcast remote. have idetified correct code and and can turn TV on & off with remoet but can not get channels to change .... just get static no picture ??? Can...
The Comcast remote only changes channels on the cable box. not the tv itself. If you have a cable box then the tv will need to be turned to channel 3 or 4.
Apr 11, 2011 | Quasar VV-1302 13 in. TV/VCR Combo
How do i get the lock and unlock on the screen to work on a viper 479v remoet
The two-way remote responds when in range. Also, the system that it is programmed to must be a two-way unit. If this remote was purchased and programmed to an alarm/remote starter, the alarm/remote starter must be capable of two-way communication.
Jan 25, 2011 | Directed Electronics 479V Remote Gen 2...
Need tv code numbers for gemini universal tv remote so i canprogram to my magnavox tv set
Code for your Gemini universal remoet to progrmme your magnavox TV are
080,120,130,190,270,300,0054, 0706, 0030, 1454, 1254
Thanx
Aug 05, 2010 | Gemini 1 Device Universal Television...
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Remoet control fro my hitachi plasma tv, wont sitch on /off but does other options
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 30, 2008 | Televison & Video
Can you help me program my remote?
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Code and instructions foremote radio shack 15-2114
I lost my manual for my remoet cat,no, 15-2114. Could someone help me with the code for a hitachi 60" TV?
fandrewszion
Jan 11, 2008 | Radio Shack 15-2200 Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
