Question about Kitchen Ranges
How to replace bulbs on the Cooker Hood Cata Isla C900 Curved Glass Extractor
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
  • 50 Answers
SOURCE: Indesit cooker hood.
some have fuses, some dont. i know that if you dont have the vent hood hooked up correct the heat can melt the wires on the inside. so make sure the vent is hooked up right.
Posted on Jun 23, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
manhandy
  • 146 Answers
SOURCE: Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Posted on Jul 05, 2009
  • 72 Answers
SOURCE: bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Posted on Jan 04, 2010
Hi I have an Ikea cooker hood/ extractor fan, fan is working but lights ( 12 V. GU4 ) are not. Just replaced the bulbs but no joy.....
Without the MODEL Number... and the 12v GU4 lamp... I am going to HAZARD A GUESS that your lighting has an internal TRANSFORMER... (most likely)...
But there are less expensive things to check first
Since this is now a GLOBAL SITE you will have to disclose your Line power... (USA: average household range hood = 120V 60 cycle AC current)...
ERGO:
transformer is a 120v to 12volt output (live measurement)
For walk up TROUBLE SHOOTING
"Multi-meters" are a must...
Opening assumption
THAT YOUR NEW BULBS are good... is understandable... but possibly wrong (I'm just saying).
Power OFF
- Verify bulb continuity
- Verify switch operability
Happy hunting
Carnac the Magnificent
Feb 07, 2017 | Kitchen Ranges
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
Installation and operating manual for a Prima LXP70 Curved glass extractor hood
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 31, 2010 | Microwave Ovens
Light on cooker hood doesnt work
check the switch, if you got power then the switch or bulbs sockets.
Jun 22, 2009 | Kitchen Ranges
Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
Baumatic cooker hood lights not working
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Belling cooker hood chim101 BL - light/ lamp
I just had this very same problem and believe I have solved it!
You can remove the entire light unit from the hood. On first inspection it appears to be a sealed unit that does not allow you to remove either the wires or what looks to be a regular halogen bulb. If you turn the unit so the bulb is facing you, you can gently prise the glass from it's housing leaving the naked halogen bulb exposed beneath it. You can gently pull this from the housing and buy a new one to replace it. I would advise that when installing the new one you make sure it is completely free from any contaminant as any grease etc can greatly reduce the life of the bulb. Hope this helps!
Nov 04, 2008 | Kitchen Ranges
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
