Question about Canon imagePROGRAF iPF8000 Printer
HOW TO FIX ERROR 03130031-2F26
ITS DOING IT EVEN IF I RESTART
    Top Expert:
  • Canon Master
  • 6,702 Answers
This question was already solved on fixya. See the link: Canon Hardware Error 03130031 2F26
Posted on Nov 22, 2014
I keep getting an error that says Lightroom encountered an error when reading from its preview cache and needs to quit. Lightroom will attempt to fix this problem the next time it launches. This keeps
You need to delete the Preview Cache. It is located in the same folder as the Lightroom Catalog. The preview cache name ends with Previews.LRDATA and should be deleted. Do not confuse this with *.LRCAT, which should not be deleted.
Sep 17, 2014 | Adobe Photoshop Lightroom
Tip
Windows Defender 0x800106ba Service Error on Automatic Startup
Some times even when the Windows Defender service is set to automatic you still might see the Error below and even when you have tried this site http://support.microsoft.com/kb/931849 which tells you to remove the program and then use the windows installer cleanup utility form HERE and start again you still get the same error
This is a method is bit drastic I suggest that first you update manually the definitions from HERE then download my Windows Defender FIX from my Public SKYDRIVE then restart you PC it should now fix the above error it will re-register all the DLLs that are needed to allow the error to go
on May 01, 2010 | Microsoft Windows XP Professional
Phaser 8500 error code 19,003.48:64663
19.003:48 is the error code 64663is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
Dec 12, 2013 | Xerox Phaser 8500/DN Printer
Errror 85
How to fix the System error 85 has occurred?One thing to mention is that even though you may be mapping some drive letter to a network resource, the same drive letter for other Terminal Services sessions may work as expected.
Use another drive letter...
Another point is that a different drive letter that is not typically used also works as expected. If it is feasible for you, use different drive letter when mapping to your network resource.
Restart Terminal Services-based component...
If using another drive letter to map your network resource is not an option, you can try to correct the issue by restarting the Terminal Services-based component.
Restart Terminal Services...
Another way to fix the problem is to restart the whole Terminal Services service. You can do so by executing the following steps:
-> Go to the Start Menu
-> Run
-> Type services.msc and hit ENTER
-> Locate Terminal Services
-> Right click it and select RESTART
This should break the connection between the Terminal Services and the resource and make the network drive letter available for your use.
Upgrade Windows...
The good news is that some attempts have been made by Microsoft to handle this error message and the underlying causes by Windows. The System error 85 has occurred was often visible in Microsoft Windows 2000. The Service Pack 3 and Service Pack 4 include some fix for this.
Sep 06, 2012 | Foxconn Computers & Internet
Create card problem run time error Fmnot32.exe
rename fmnot32.dat to fmnot32.old, rename fmnot32.bak to fmnot32.dat, then restart. It fixed mine today! Good luck
Sep 17, 2009 | Broderbund American Greetings CreataCard 2...
Error in registry....
Maybe, you have registry problem.
  • Just restart the system
  • Press F8 while starting the windows
  • Select "Safe Mode" options
  • After restarting, a window will come up on screen
  • select No
  • Just select the past date from the date calender. You must select a past date from which you were not facing problem.
  • A restore process will start automatically.
  • press okey and finish
  • restart the computer.
Dec 10, 2008 | Microsoft Windows XP Professional
Toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Aug 28, 2008 | Toshiba Satellite A135-S4527 Notebook
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
WE WENT TO THA BEACH AND TOOK SOME PIC AND LATER THAT DAY WHEN WE WENT TO TAKE MORE PIC IT SAID LENS ERROR RESTART CAMERA BUT WE DON'T KNOW HOW TO RESTART THE CAM
Aug 18, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 31, 2007 | Cameras
Canon imagePROGRAF  iPF8000 Printer Logo
805 people viewed this question
old marine
old marine
