I have tried diagnostics with the Nissan consult 3 computer. Only fault code given is problem with Coded Line Circuit. Only light that comes on is the red light on the instrument cluster. No ignition lights and the car only cranks.
SOURCE: ignition switch...instrument lights...won't start
sounds like a loose connection or broken ignition switch to me that is where i would start looking hope this helps regards Jim
SOURCE: instrument cluster panel
The transistors are BST80, the numbers are just SMD codes, but the reason to make transistor to fail is the illumination layer is faulty. There is also a transformer which may have open circuit You should check that either
SOURCE: nissan almera 2003
This is on the air/fuel sensor that is mounted in the exhaust manifold right behind the radiator. You will need to remove a heat sheild to see it but you should see the wires coming out of it. Also a spiecial socket is needed to get it out without damaging the wiring.
SOURCE: P1403 DPFE
this basically means the EGR valve has been wrongly connected, the hose is partially off or is faulty, also the hoses like to block up with a carbon build up wich will cause the valve to stay partialy open giving you a poor idle
Testimonial: "Thanks bob nowwhere is it?"
