Question about Cell Phones
How do i flash my phone when the screen is blind because of virus,it cannot on
To on it but it cannot on very well,it will be showing white screen
    Top Expert:
  • Cell Phones Master
  • 6,702 Answers
Never try to update or flash any device you don't trust to work for 100% correct. You could try to reset it to factory settings. For flashing or updating you must be sure the own software runs stable, because this software is needed to put the data where it should be.
Posted on Nov 22, 2014
2 Suggested Answers
wiqi546
  • 1511 Answers
SOURCE: White screen which keeps flashing problem
Hello and Welcome to FixYa!
Common problem know as WSOD (White Screen Of Death)
The only solution is to Flash the Firmware, BUT Note that when you turn your phone on, IF there is a pluse vibration (Just for a sec) THEN this solution will work.
The whole solution is well described in this article, again let me clear you it is a 100% working/tested solution, I'v done it successfully many time, but as you are a newbie, so throughly read the article before continueing and if you got any confusion, DO ask me here by posting a comment.
If I was helpful, kindly do Rate!
Regards, Waqar.
Posted on Oct 05, 2009
White screen how do i retrieve the contacts from it connected to pc with usb cord what software or such is needed?
this is not possible because the screen is blind. When you connect the phone to PC, you need to accept/press something on the phone to connect to the PC. Now the screen is white, you can't see what button you are to press on the phone.
I would suggest you replace the screen. Also, if your phone uses sim card, you can remove it from your phone and insert it into another phone. You might be lucky to find your contacts on the Sim.
Now to fix the problem, read further:
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Regards.
Walesarumi
Sep 28, 2011 | Samsung SPH-m520 Cell Phone
Tip
Screen problems on phones
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
Software/Virus:
Flex problem
on Oct 12, 2010 | Cell Phones
My phone turns on , shows the nokia screen , then the screen goes white and then its turns off. please help
Hi, most problems with mobile phones when it turns white and goes off, is usually a problem with "VIRUS"on your mobile phone.
Causes are when your using mobile internet and you decide to do some downloads on your mobile, or can be through transferring DATA from a phone to another phone, transferring from PC to phone with out you noticing that you have downloaded VIRUS with applications without scanning for VIRUS before uploading it on your mobile phone.
So in this process, VIRUS then affects the cell phones memory and cell phones starts malfunctioning by switching off when you try to put it on,or make calls..
To rectify and solve this problem to be able to restore back the lost memory of then mobile phone, you will need to flash the cell phone.
Flashing the phone will restore back the phone to it normal state.
You can use this link to see how to flash your phone
Flashing a cell phone will erase carrier data from the memory. Cellular companies can usually do this for a fee. Online buyer sites sell the software kit that will flash a cell phone from home computers.
To flash a phone you will need to rewrite the PRL file by connecting your phone to a computer with the needed equipment. Your best bet is to take your phone to a dealer that flashes phones on a regular basis. For more information
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Thanks for using fixya.
May 28, 2011 | Nokia X3 Cell Phone
Nokia 3110 white display
whats u r problem
Mar 02, 2011 | Cell Phones
3110c shows the white screen and switch off automatically....
My advice is that you go and flash it, the phone has virus or other problem. Try it and be good to give me feedback.
Nov 26, 2010 | Nokia 3110 Cellular Phone
N95 black creen
Software/Virus:
Flex problem
Good luck.
Aug 27, 2010 | Nokia N95 Cellular Phone
My Nokia N70 shows white screen only when turned on and will not respond to any input ..how can I reboot the system..my PC shows no connection and will not recognise my N70
hi,
there are two kinds of white screen in n70 ,the first one is because of damage LCD (glass screen) ,defective display driver (small chips that makes the display works) and the other one is corrupted software...in damage lcd the phone will detected by computer because its software is still working...so ,the problem of your N70 im sure is the second one ,corrupted software....your phone needs to reprogram,and need to go to a nokia care center to fix you problem...i hope ,i will help you ,thanks for trusting fixya...
Jun 15, 2010 | Nokia N70 Cellular Phone
The LCD og my phone sony ericson w550i turning to white
When it shows white, can you recieve or make calls? If you can recieve or make calls, that means the fault is from the screen but if you cannot recieve or make call, it means its a software problem (virus).
For screen fault, the screen needs to be replaced.
But for software problem, you need to take the phone to a technician. The technician will use computer to flash the phone for you.
Take care
Dec 16, 2009 | Sony Ericsson W550i Cellular Phone
My sony ericsson W550i shows white screen
some virus are cant find while scanning ok it will be a virus only so you format a data in your memory card
Jun 03, 2009 | Sony Ericsson W550i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
