Question about HP Cameras
I have a HP camera model GRLYB-0310 and it does not read the memory card . Can the camera be faulty ? How can it be fixed ?
I already changed the memory card for another , both cards are new . All other things seems to be working , but if it don't read the card you can't take pictures .
  • 23 Answers
It could be that the card is faulty, even a new item might be bad as the manufacturer only dose random sample checks and not all the chips are tested. before buying a new camera buy a new card it might also be that the card is not compatible with your camera
Posted on Nov 22, 2014
SOURCE: Memory card problem
I had the exact same problem, and i had no luck finding a solution, so i was messing around with it, and i figured out what the issue was. Go to Menu and then to the SETUP option. When you scroll down there should be a USB option. Change it from Digital Camera to Disk Drive, and your computer/camera will register that it has a card in it!
Posted on Jun 01, 2007
  • 13 Answers
SOURCE: CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
Posted on Apr 23, 2008
SOURCE: Cybershot camera not reading the memory stick
Have you tried reformatting your memory card itself?
Posted on Jul 21, 2008
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Posted on Sep 11, 2008
SOURCE: problems with hp grlyb-0310
I turn on my camera and the screen just flashes. I have pushed every button but can't get it to turn on. help!
Posted on Oct 02, 2008
Three beeps at interval no thing on monitor. what can i do? ihad just loaded a new os and was working fine.i shut down and change memory stick.turn back on and hear these beeps.re-install origin memory...
Beeps are mainly caused by bad, dusty memory module or the port it is connected to. However, since you have tried changing it with a working one and i suppose you already clean it that's fine. One more hardware which causes beeps is the video card. If you have a video card installed, it may be moved when you change the memory module. I suggest you try to reseat the video card as well..
Hope that works
Feb 13, 2011 | Asrock K7S41GX Motherboard
When I start the camera, it says in red "this card
hi there...
i have once experienced the same as you
try to format it with your laptop/PC, then reformat again using camera option
if still don`t work, i assume the memory card is broken and you`ll need to buy new one
Jan 13, 2011 | Nikon Cameras
How to restart nokia 2626
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens.nokia 2626 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - nokia 2626 mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent nokia 2626 from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling nokia 2626 phone memory.
Cause 3 - Memory Cards - Some people have reported that nokia 2626 restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their nokia 2626 mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your nokia 2626 phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this
Good luck
Jul 09, 2010 | Nokia 2626 Mobile Phone
Brand new memory card
I have the same problem with the same camera. I checked other sites and it seems that the C330 takes only SD cards up to a max of 1GB. It won't read SDHC cards and it won't read SD cards greater than 1GB.
Jul 03, 2010 | Kodak EasyShare C330 Digital Camera
Can u help me to format my nokia 3110c phone???
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Jun 29, 2010 | Nokia 3110 Cellular Phone
I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Cause 5 - MP3 files
Feb 12, 2009 | Nokia 3110 Cellular Phone
Formatting internal memory of nokia 3110c
Cause 5 - MP3 files
Jan 14, 2009 | Nokia 3110 Cellular Phone
Can't format 2Gb Extreme III SD card in Canon G9 camera
bad card trash it and get new one changeing formats will cause errors most camera's use their own format if u cange it from one to the other so many time it burns card out
Dec 28, 2008 | SanDisk Memory Media
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Cameras Logo
101 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
