Question about Samsung Refrigerators
How do I change the light bulb in the fridge of Samsung RL41SBTB fridge freezer?
I can't remove the plastic cover.
  • 37 Answers
Pull the cover by identifying the lock on top and bottom
Posted on Nov 22, 2014
  • Emma Bier
    Emma Bier Nov 22, 2014
    Thanks but what lock top and bottom? see pic.
  • 1462 Answers
SOURCE: FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Posted on Mar 31, 2007
  • 1462 Answers
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
  • 306 Answers
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Posted on Jan 01, 2009
VtToolMan
  • 704 Answers
SOURCE: Lights staying on
You need to replace the door switch, as it is allowing the interior light to stay on, but also it's keeping the fridge section circulating fan from coming on, and that is what is really causing the interior to heat up.
It's located in the top hinge plate cover and you can test for faulty operation by removing the switch and connecting or disconnecting the wires together to see if your light goes out and the circulating fan starts to run. If so, the switch needs to be replaced.
The part number is #6600JB3007K and costs about $8.00. You can order it from several online sellers or at www.searspartsdirect.com
Here's a diagram of your fridge and the parts list with pricing.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=LFX21971ST&productCategoryId=0161000&brandId=3204&modelName=BOTTOM-MOUNT-REFRIGERATOR&diagramPageId=00001&componentDescription=CASE%20PARTS&documentId=F0902046&backToLink=Return%20to%20Sub%20Components%20list
Hope you found this very helpful and best regards!
Posted on Aug 07, 2009
localwonder
  • 6784 Answers
SOURCE: lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Posted on Dec 11, 2009
I can't figure out how to remove the light bulb cover to change the light bulb. Followed directions in manual, but it won't budge. I fear breaking it--it takes only light pressure supposedly!
Some of the covers are molded plastic, give them a squeeze and they should release from one side. Some have metal latches on a glass panel to flip out of the way before you can slide them one direction or the other... but the manual is correct, it shouldn't take much force.
Apr 23, 2016 | Viking Refrigerators
How change freezer light bulb on model LFC 21776
yes to both, and I believe to remove the light bulb cover you gently lift up and out to gain access to the bulb.
Sep 18, 2014 | LG LFC21776ST 21 CF French Door Refer Cab...
Lightbulb not working in fridge freezer.How do I remove panel to get to bulb
Try pushing the sides of the plastic to remove it. Then you can access the bulb. Do not remove the bulb with your bare hand. Use a dry towel because if the bulb breaks in your hand, you have a problem. Unplug the fridge when you do this.
Feb 02, 2014 | Refrigerators
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
I have a Samsung Cooltech Fridge/Freezer.....I changed the internal light bulbs and have no Internal light....what do I do ?????
before I sugest an idea I will ask you to make sure the new bulbs are not damage you can make a test with anything you may have at home that requieres a bulb less than 100 watts.if the new bulb is working unplug the fridge and try to pull out the center of the socket were the bulb rest is a small metal plate.use a pen,pensil plastic knif or regular kitchen knife tu open it but no to break it all the way just make sure your fridge/freezer is completly UNPLUG FROM THE POWER OUTLET
Aug 12, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
I have a Samsung refrigerator Model RT52EAMS which is 5 years old. It is working fine except that the light in the refrigerator is no longer working. The light in the freezer is still working well. How...
Please check the door switch and the bulb holders, in some cases it can be due to loose connection or a faulty switch on the door, The failure of the bulb is another issue but the main subject is how you can check and remove the bulb.
Please check on the link below for tips and spares:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/280/common-fridge-and-freezer-faults.html?k=#nolight
Jul 19, 2011 | Samsung Refrigerators
I have a Hotpoint HMB313I integrated fridge freezer. When I open the fridge door no light comes on. Should there be a light in the fridge? If so, could you tell me please where the light(bulb) is located...
Hi!!
The light bulb is usually located in the center top of the fridge box, you may need to get on your knees and look up to see it. They usually just screw out, in case there is a plastic cover, just squeeze it and remove it. The replacement bulb can be found at Walmart or KMar it is call Appliance Bulb.
Good Luck!! Don't forget to rate this post!!
Jul 18, 2010 | Hotpoint Refrigerators
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
The light bulb needs replacing but..
It would have been really helpful if you could have provided the model number. You can always find it at the back of your freezer. Here are some links to videos which should be useful for you.
Jul 22, 2017 | Refrigerators
Refrigerators Logo
100 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
