Question about InFocus Office Equipment & Supplies
My infocus projector accidentally entered 12 volts at the back instead of 5 volts.
Just checking what was burning but didn't see any burned parts its new piece anyway 1 day old only.
  • InFocus Master
  • 3,382 Answers
If it does not work you destroyed it and the manafacutrer in not responsible for your problem.
Posted on Nov 27, 2014
I am a technician I would like to ask if how can I repair my Infocus projector model 3116 ,I accidentally entered 12 volts at the back itself to the 5 volts output jack.
Don't know how to fix this, but it sounds as if you may have blown it out and cant be repaired, after seeing smoke .that usually means it is now a paper weight . Sorry if my answer offends you
Nov 22, 2014 | InFocus Office Equipment & Supplies
The ignition coil is burning and the car won't start, what should I do?
check the voltage of the coil and ensure that you have the correct one. They come in 2 voltages . One is straight 12 volt and starts and runs on 12 volts. The other is 12v-7 volts . It starts on 12 v and runs on 7v through a resistor . Burning coils is an indication of the incorrect voltage in the run position. Leaving the ignition on when the engine is not running ( turning on the key to listen to the radio for a period of time) instead of using the accessories setting will also burn out coils.
Nov 07, 2013 | Cars & Trucks
After bulb burns out during church service and fan is running when power is turned off and bulb is replaced. Projector will not power back up.
Hi, I would suggest that you give it more time to cool down in the future, that is why bulb burned.
There could be more heat damage to projector. Check for reset botton and push carefully. listen for click. Look at main switch with more detail (worn out) Bring to be repaired. Good luck.
Jun 13, 2011 | InFocus DP8200X R Refurbished LCD...
I have infocus LP120 and the bulb burned out the other day. I installed a new bulb and it starts up fine except there is burning smell from the vent. Is it normal? Some guys told me it's "burn-in" process...
Yes it is normal, but there were issues in the past with the lamp burning the lamp cables. Infocus then upgraded the cables with slightly heavier gauge wire and better thermal tape around the wires. It would be hard for me to tell you if yours has the upgrade, but if you got it from Infocus I'm sure it is good.
Aug 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
I have a infocus 4805 projector the bulb quit on me due to over heating i guess, any way it cracked and burnt out. I ordered a new bulb which i received and installed. I watched half a movie and had to...
first thing's first- clean the dust out of the projector with canned air. excessive dust and heat are death to a projector. then check the colorwheel. if you don't hear a high-pitched whir or you hear a buzzing, the colorwheel needs to be replaced. the lamp won't strike without it. next check both fans. you may need to take the top off to do it. if both fans don't spin properly, it will overheat. many times the larger fan (lamp fan) will burn out or the circuit that starts it burns out. next, check the new lamp. does it have black spot, bulges, or fogging? if so, you'll need to replace it. if you do have to, don't get the cheapest one from "bob's lamps" online. you get what you pay for. if all that is ok, then you have a bad power supply. it's rare that this model has ps issues, but it's not unheard of. you could get the part(s) from an infocus service center, or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 20, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have an InFocus SP5000 projector that has started showing a green glow in mid-screen (center). Before I buy a $300 lamp want to know the cause of the green glow.
either the light filter behind the blue lcd panel or the fly-eye lens (both inside the optical engine) have developed a burn spot from overheating. infocus doesn't sell individual parts for the optical engine, and the whole thing must be replaced. but unfortunately, it's the most expensive part of the projector, usually upwards of $2000 (and there's none in stock).
Jun 24, 2009 | InFocus SP5000 Home Theater Projector,...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Projector getting too hot
comman to a projector to get hot in front and top center part
but not at the rear side
this might be
fan not working
filter need to clean
bulb life getting lower
open the cover check safety paper
might be burn out
replace new one.any hard paper
Jul 10, 2008 | InFocus Proxima DP6155 Multimedia...
44 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
