Philips shoqbox SB7200 not charging properly any more, after a night on the charger it plays for 5 min and then shot down. Guess batty is dead so how to change it?
SOURCE: HS820 "dead"? No blue light
Toss it. They aren't replaceable. You have to break open the case (glued shut). Even if you opened it, the replacement would likely cost you what it would to replace the whole unit.
I'm in the same boat.
Posted on Nov 26, 2007
Agent Ken
  • 250 Answers
SOURCE: Ipod Nano won't hold a charge
Hello oob5491,
The battery may be going bad. The internal battery in the ipod has a limited lifespan and will eventually fail. When this happens the amount of operating time you get between charges will gradually decrease unti eventually the unit will not stay charged. It sounds like this is what you are experiencing.
You will want to contact Apple about the unit to get more informaiton on getting battery refresh service,
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 26, 2008
  • 26 Answers
SOURCE: My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
Posted on May 16, 2009
SOURCE: what kind of charger does a shoqbox need?
It needs a Philips AC adapter Model: AY3197/00
Spec:
Input: 100-240V 50/60 Hz
Output: 5V--2A
Posted on May 19, 2009
buffalonyman
  • 1865 Answers
SOURCE: 2006 dodge charger battery is completely dead and will not charge properly or allow me to jump it.
You need a new battery.
Posted on Jun 03, 2009
Bought 2 tablets for our kids and the chargers don't work?? HELP
If they are after market chargers then they are probably not putting out the proper voltage... if they are proper chargers it could be the wall plug is reverse polarity... a 5 dollar wall plug tester which looks like a mini charger and bought at any local hardware store can tell you that with its 3 light system.... be surprised how many are wrong in a house.. if that isn't it the charger maybe shot... unlikely two different chargers are bad though... more likely a second hand pad with dead batteries... which means a trip to the repair Depot. But if they are stolen ...
Apr 06, 2016 | Tablets & eReaders
Philips shoqbox
You have a file error: a system file may be missing or you have a format error on the SHOQBOX. To fix this problem: 1. Connect the SHOQBOX to the computer using the supplied USB cable. 2. Plug your SHOQBOX into a wall outlet with the supplied AC adapter. 3. Launch the Device Manager at Start->Programs->Philips->Philips->PSS110 (or the model number of your SHOQBOX) on your PC. * IMPORTANT: All music & content of your SHOQBOX will be erased once the factory setting is restored. 4. A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting. 5. Follow the on-screen instructions to complete the restoration. 6. The Device Manager will close automatically once the success message is displayed. 7. Transfer a couple of songs into your SHOQBOX to confirm if the SHOQBOX has fully recovered all the files. 8. Close all opened applications and safely remove your SHOQBOX by clicking on the icon on your Windows task bar tray. 9. When prompted, ?The USB Mass Storage Device can now be safely removed from the system?, click OK and unplug your SHOQBOX. 10. Your player will display ?UPGRADING FIRMWARE?? once disconnected from the computer. 11. After firmware upgrade is complete, it will reset itself, showing the PHILIPS splash screen. 12. Press to switch on the player again.
Sep 12, 2007 | Philips ShoqBox PSS120 MP3 Player
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Jun 17, 2009 | Jazz DV-179 Digital Camera
What kind of charger does a shoqbox need?
Spec:
Output: 5V--2A
Apr 04, 2009 | Philips ShoqBox PSS120 MP3 Player
Can't Seem To Find The Music On My Shoqbox
Search for a program called 'Shoqbox buddy' which will rebuild the database on your player. Operation is fairly self-explanatory.
Once you run the program and navigate to the right location on the player it takes seconds.
Dec 27, 2008 | Philips ShoqBox PSS120 MP3 Player
Cant turn my phillips pss110 after taking it out of the computer
does the device immediately shut off after displaying the Philips boot screen? if so, the mydb internal database file may be corrupt or missing.
Get the free program "ShoqBox Buddy" and use the "rebuild database" function to see if that fixes it.
Nov 03, 2008 | Philips PSS110/17 MP3 Player
Shoqbox not playing or showing song loaded
Make sure you have the version of the Musicmatch from the Philips website first, and try again - Musicmatch discontinued their service in Oct 2007, making this particular Philips mp3 player obsolete.
Also, make sure the files you are trying to load are in Mp3 format specifically - this player cannot take DRM-encrypted WMA files.
Jun 09, 2008 | Philips PSS110/17 MP3 Player
 Grubhead
Grubhead
