Question about Jura ENA Micro 9 One-Touch Automatic Coffee Center
What is error 6 and how too solve it?
Turn machine off at power point and unplugging it. Then turn machine on make a grinding kind of noise then eventually heating shows for a whil then error 6 comes up and machine turns off.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Hi, I made a video how to fix your Jura step by step, good luck,!
http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Posted on Mar 23, 2015
C350 grinding noise does not power up
Open the right door and remove the fusing unit and turn ON the copier.If the copier turn ON and the error code displayed the problem in the fuser drive transmission mechanism(gears),if not working remove the rear cover and verify the main suplly unit and the main motor.
Mar 20, 2013 | Konica Minolta bizhub Office Equipment &...
Error and loud beeping
Hi Cathy, Unfortunately I am not familiar with the J5780 machine. Sorry I could not help. Kind regards Printdesigns
Nov 29, 2011 | HP Officejet J5780 All-In-One Printer
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
My printer is making a weird noise and the power light just blinks
Turn off the Printer
open the Front access Door, Check if there is bits of paper or dirt on the ROD that moves the Cartrige/carriage.
Move the Carriage freely 5-6 times from left to right ( it should move smoothly )
Remove the Cartridges, Clean the contacts on the Cartridge ( golden Contacts)
Open the Rear Access door, Clean the Rollers with lint free cloth.
Close the Rear access door and front door
Power on the Printer. If the grinding noise continues, Unplug the power cable from back of printer ( while printer is on ) and while holding the # and 6 button, connect it back.
It should go thru alignment process and the grinding noise should be gone. If it doesnt, probably.. its time for new printer of HP again.
Jun 24, 2010 | HP PSC 2410 All-In-One InkJet Printer
PRINTER MAKES A LOUD SOUND LIKE A MACHINE GUN WHEN IT PRINTS
Jun 24, 2010 | HP Officejet J5780 All-In-One InkJet...
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to http://neilcrockett.com/mixer.htm.
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Switch printer on,just get grinding noise on right hand
try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Delet code
It's an calibration error caused in the optics section. Make sure there is nothing on the scanner glass but the cover itself. Turn the power off, wait 30 seconds and turn the power back on again.
Do you hear any grinding noises when the machine is initializing?
Aug 08, 2008 | Sharp AR-5316 Advanced Digital Imager...
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Jura ENA Micro 9 One-Touch Automatic Coffee Center Logo
621 people viewed this question
Top Jura Coffee Makers & Espresso Machines Experts
cramsey548
Ross Keen
ray gallant
Are you a Jura Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
