Question about Samsung AQV24VBE Vivace Wall Mounted Indoor Unit Air Handler 24,000
A short while after turning the unit on (AQV24V) it displays the error code E4 64. does mean? Thanks
Turning the unit on and then off. Ensuring all setting requested are reasonable eg requested temp 25C room temp currently 30C
    Problem Solver:
  • 6 Answers
  • Samsung E464 Code=IPM Over Current
Measure the current into the condenser to see if this is as per name plate,then check the gas charge
Posted on Nov 24, 2014
WHAT DOES ERROR CODE f11 MEANS?
Resolution: Error code F11 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
Unplug or turn the circuit breaker off for 30 seconds.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
24 7 Locksmith Amherst Ny 716 200 1030 Amherst Ny 24 Hour Locksmith Car...
Aug 07, 2016 | Whirlpool Washing Machines
What does f01 mean
From the Maytag support website:
Product Symptom:
F01 Error Code
Control displayingF01:
There may be a problem with the Main Control Board, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Start a time dry cycle.
Monitor the dryer for one (1) minute to ensure the error code does not display again.
Jan 24, 2016 | Maytag Dryers
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Error Code F@ on GE XL$$ Range
    usually f02 means you have a shorted keypad. does it randomly beep at you if so this is a symptom. you need to replace your keypad
    May 29, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    Error code on kyocera fs-3800 printer
    E1: xxxxxxxx = Main motor error
    Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
    below is stuff from service manual and ....my comments
    Suggested causes
    The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
    • Connector insertion error........check developer plug is secure (left top near toner cart little plug)
    • Defective gate array U204 on the engine
    board (KP-864). .......replace board
    • Defective harness between engine board and
    engine relay board (KP-760). .........secure replace cable
    • Defective harness between engine relay board
    (KP-760) and main motor.
    Nov 26, 2007 | Kyocera Mita FS 3800 Laser Printer
    Error Code "F76"
    spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
    Apr 10, 2006 | Panasonic SC-PM08 Shelf System
    Samsung AQV24VBE Vivace Wall Mounted Indoor Unit Air Handler 24,000 Logo
    272 people viewed this question
    Top Samsung Heating & Cooling Experts
    billconfused
    Ezewudo Onyekachi
    Ezewudo Onyekachi
    Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
