My samsung hln507w1x/xaa tv turns on for a couple of minutes then shuts.all 3 lights are blinking
Slinteriors
  • 8617 Answers
SOURCE: tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Posted on Jan 22, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
  • 304 Answers
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
Posted on Jul 16, 2009
SOURCE: blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Posted on Apr 22, 2010
SD Tech
  • 14553 Answers
SOURCE: replace dmd board samsung hln507w1x/xaa
You will have a couple of problems here: This model may use 2 completely different DMD boards---need to get the right one.
Also, DMD is usually about 400 dollars and entire light engine with a new DMD is about 450-500-----they really don't want to sell them.
If you were to replace the DMD you would have to get at it (it is on the back of the optical engine and usually you have to remove another unit bolted up behind it, remove a fan in back of it and then release 3 long recessed bolts to take it out.
I did these and they are not easy---when you install the new DMD you have to POSITION THE DMD WITH THE SET ON---it will center the picture up/down and left right--moving it up slightly moves the picture down-----every action is opposite of what direction you move it.
Presuming you get it centered you have to tighten the three bolts slowly---as you tighten they tend to move the picture in some direction.
I think you get the idea---the DMD is not a "easy" part to properly replace.
The shop I work for---we have tossed several of these sets to be recycled as the cost of the part is more than the set is worth used.
If this information told you something you did not know, rate this solution as I do this here for free.
You may also want to contact SAMSUNG as there have been some programs where they will cover the replacement because so many failed and lawsuits were started etc.
REGARDS, SD TECH
Posted on Aug 13, 2010
Samsung txr3079whx/xaa 5 blinking lights
5 blinks to Samsung indicates a fault in the main power supply output voltage.
Jan 23, 2013 | Samsung Televison & Video
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Blinking lights on HLT5075SX/XAA samsung
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Training Manual for HLN617W1X/XAA
Try Googling (Samsung)(HLN617W1X/XAA)(manual) without parens. For a service manual, you may have to contact Samsung directly.
Nov 07, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
