Question about HID Corporation HDP5000 Card Printer
My hdp5000 card printer gets error 93 wrong ribbon. i use to check if the automatic detect option can solve this but the option is unable to click
How to solve error 128 Fargo hdp5000
That error code indicates that a ribbon calibration should be performed. Please download the (free) Fargo Workbench Utility program (Drivers Downloads), and perform the ribbon calibration from the Printer Information tab, and then testing screens within.
Feb 13, 2018 | Fargo Office Equipment & Supplies
How do I print edge to edge on Fargo HDP5000?
Access the printer-driver settings (Windows=>Devices and Printers=>Right-click on device, select "Printing Preferences"). Next, click the "Image Transfer" tab. Here you can make some adjustments to the image position - both vertically and horizontally.
If this doesn't help, double-check your page-size and print-parameters in your software. You should be outputting to a "CR80" sized card, and (if present) your margin settings should be 0 for all of top, bottom, left, and right.
If that doesn't help, then you may have to perform ribbon and/or film calibrations. These are available through the "Self Test" menus within the Printer Information screen of the (free) Fargo Workbench Utility program.
Dec 30, 2015 | Fargo HDP5000 Thermal Printer
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Ribbon miscue on cyan fargo hdp5000
There are a few things which could lead to a ribbon miscue. The most obvious would be your firmware. Go to Fargo's site and download the latest firmware patch. Your printer may driver be corrupted, so uninstall and then re-install it. One other possibility is that your printer has a faulty ribbon sensor which would need replacing. I hope this helps
Aug 11, 2012 | Fargo "HDP5000 Single Sided Card Printer,...
I have ribbon and am using photoshop,how do i print uv with hdp5000?
To print with UV on a Fargo HDP5000 printer you first need to get a UV color ribbon: YMCFK. The part number is 84061.
After you have your UV ribbon installed you will have to load your cards and tell the printer where you want that special UV logo/design to go. The easiest way to do this is by using Asure ID Solo 7 software. This design software is made by Fargo and has a check mark box on the top where you can either turn the UV design on or turn it off depending on how you plan to create your card. Asure ID Solo 7 costs about $150 but it's very easy to use and makes the print process easier.
There is a second option which involves not using Asure ID and instead creating your UV design through Fargo's "Work Becnch". This process of creating UV designs through work bench is slow and not the most efficient but it is free.
Sep 28, 2011 | Fargo HDP5000 Thermal Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Error 97, Ribbon not broke and is new but cannot get past this error
I have the same problem, printer is brand new and i cant get pass this error. by any chance did you solve it? Can any one help plz
Sep 13, 2010 | Fargo HDP5000 Thermal Printer
Ribbon error code 97
Fargo HDP5000 is the most stupid unpractical product and it waste our time and effort
I think HID must stop production of all Fargo Printers
I had a lot of problems everyday from this stupid expensive useless HDP5000
Jul 08, 2010 | Fargo HDP5000 Thermal Printer
Fargo HDP5000 HDP5k H5k Ribbon Breaks Error 97
You need to update the printers firmware. 9 times out of 10, this is the issues I see.
Go to HIDglobal.com. Under the support tab, select Drivers & Downloads. From here, populate the drop down menus with Make and Model. Compare the available firmware with the firmware version current installed on the printer.
Hit [Options] then [Next] on the printer to figure out the version.
On this same web page, make sure to download the Fargo Workbench Utility. It gives you the ability to update.
Aug 06, 2009 | Fargo HDP5000 Thermal Printer
HID Corporation HDP5000 Card Printer Logo
272 people viewed this question
Top HID Corporation Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a HID Corporation Office Equipment and Supply Expert? Answer questions, earn points and help others
