SOURCE: Casio Exilim EX-S600 time and date entry at every startup
Even casio seem confused by this question! It seems that the camera will loose it's settings if the battery is dead or the camera is not connected via USB. Even if the battery is charged it could loose the settings within 24hrs. You can get the manual below: http://world.casio.com/qv/download/en/manual/
SOURCE: Casio Exilim EX-S600 LCD broken. Needs spare part
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
SOURCE: Casio Ex-Z75 Battery not charging ?
This problem is known. There is a way to fix it.
The fact that it blinks on and off means that the battery is completely out of energy. Thus, the charger doesn't "recognize" the battery.
To fix the problem, you need to give some energy to the battery. What I usually do is that I use a 9V battery (or any other source of power) and I link + and - of both the Casio battery and the 9V battery. You can use a paperclip as a link (you will use 2 paperclips, 1 between minuses and 1 between pluses).
Do that for 2 minutes and then charge your battery as usual. It should work !
Sorry if my English isn't accurate. I'm French.
SOURCE: Battery Problem Casio EX-S880 Digital Camera
Ive had this happen twice. The first time I went back to the store and talked to the tech people to see if it was a problem with the camera itself but ended up buying a new battery. About a week ago, I finally found my charger to plug in the camera that I hadnt used in weeks to find the same problem once again. It must stem from long periods of non use. After finding this question I continued my research and the Casio website tells you to call 1-800-435-7732. Dont know if that helps much but I will be calling them in a little while. Good luck.
SOURCE: my casio ex-s770 camera does not charge
There was a recall on the batteries. Call customer support and they will send you a new one for free.
