My amp blew one filter cap and some transistors and some mosfets.I replaced all 8 filter caps and transistors and the mosfets,but the protection led stays on. Where else do you think I can check? Your
I think one channel of my amp was short circuited on speaker output or overloaded with more speakers.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
You have what's known as DC Offset(a bad amplifier) you will need to check the drivers and all the fuse type resistors that are open. You need to check the rail voltages, both positive and negative, at the amplifier. You can't "shotgun" parts. You will need to check them. Be sure to reset the amp to factory defaults, but I doubt that it will help in your instance.This will be a tough repair if you're not an Audio Technician. You will need a Variac as well. For more information, or to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 23, 2014
Cerfer39
  • 709 Answers
SOURCE: overload led on 2 channels
Hi Oranzky,
Will the overload LED's light up with the Speakers disconnected?
Posted on Nov 11, 2007
robotek
  • 1512 Answers
SOURCE: SoundLab SP500 Amplifier
I strongly recommend that you replace all output transistors at once, and the drivers also. Also look for arcing across small low value resistors about the output stages, and small signal diodes also for 0.6 volts barrier potential voltage(they often go short circuit also). soft start the amp with a variac if you have one, or an incandescent 60watt 240v(110v if in the US) lamp in series with mains power to limit the current that can flow to protect the amps circuits if there are still faulty parts about. Check
DC conditions everywhere you can. If both channels appear to be ok, Then some careful observation of voltages with a DMM will help you to find any more problems.
Amps by design with high potentials and direct coupling ascociated with DC feedback loops, make this sort of work hard to do even for an experienced tech as it is very easy to damage the parts you have previously replaced if you do not check things well enough before firing the unit up. Softstarting with a variac or some sort of limiting in the power supply are generally the safest ways to approach this sort of repair. If you dont think you are up to it, refer the work to an experienced audio tech, or hitme back here and I can assist you if you wanna have a crack at it. Cheers. A "fixya" rating would be great for my 2 cents worth here. :)
Posted on Jan 19, 2008
  • 4234 Answers
SOURCE: i have a yamaha amplifier in here for repairs, the
Measure DC to ground on the output transistors to check for any offset. The protect circuit is the least likely to be the problem. Post the readings here and I'll guide you from there.
Dan
Posted on Mar 11, 2009
  • 4234 Answers
SOURCE: crown amp had 2 shorted output transistors.and 1
There is a "driver" stage that sets up the voltages for the output stage as well as a bias circuit. Any of these can have a problem. I would suggest that you take voltage readings at each of the output transistor pins and post the readings here. I might be able to give you a few things to check. Crown designs are not the simplest to diagnose, but we should be able to track it down a bit. Measure each of the pins to gound and post the values here.
Thanks,
Dan
Posted on Oct 10, 2010
  • 174 Answers
SOURCE: carverm1.0thad 2 blown caps c401 an c402 replaced amp comes on but only half the rail volts hum in right channel low output left cannot find colprut can you help thx ed @just-audio.com
there might be a couple options, speaker broke, the signial left is okay but right you send it allready distorced ,
Posted on Apr 17, 2012
Mosfet keeps exploding
Well its clear you have a nasty short somewhere, problem is with no schematics for this set how will you find the problem much less get the correct part?
Might be better to shop for a different board to replace this board with.
Dec 11, 2012 | Samsung HP-T4254 42 in. Plasma Television
I had my boss 2400 watt 2 channel amp hooked up in my car. I had one sub on each channel and one of my subs blew. I unhooked the positive speaker wire on the blown sub, everything was fine. Driving down...
If your amp started smoking, probably not. Due to your description, did the other sub really blow? I would hook it up to another amp to test it. It may have been a channel in your amp. As for repairing the amp, the parts and labor to repair will probably cost you more that to just replace the amp.
Sep 06, 2011 | Boss Car Audio & Video
I would like to replace the stock 2SC1969 bipolar transistor with a ERF2030 mosfet transistor in a Galaxy 93T.Can anyone tell me if any caps need to be removed on the amp board since C203 and L33 are not...
The radio you listed "Galaxy DX-93T Base CB Radio" utilizes a 2SC2290 final transistor. This is not a T220 2SC1969 and you cannot install an ERF2030. This is a round and white looking transistor. Replace it with only the same transistor.
Mar 11, 2011 | Galaxy Radios DX-93T Base CB Radio
I have one view sonic va1912w-4 monitor. No power from 2 days. So i can checked power cable but problem is not rectifide.What can i do check next step.
Its either going to be the power board or the main board, My assumption would be the power board since those are the more lilely culprits to go out on those monitors.
Since neither one is readly available, check the fuses on the power board and then also see if there are puffy caps. If there is then replace them with ones that are the same UF rating and same or highter voltage.
Apr 21, 2010 | ViewSonic VA1912wb Monitor
Well my ACER AL1916B LCD monitor blew up.
The MOSFET that blew up will more likely to have the switch mode driver IC that went out with it also, you need to verify that the IC is good otherwise you will blow up the new MOSFET, you may be better off buying a new board from here: http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1160140&Click=54985
By the time you order the new MOSFET and other parts it may end up more han $35, just a suggestion.
Feb 04, 2010 | Acer AL1916B 19" LCD Monitor
Start up problem.
I suggest you look at the Horizontal output transistor, when it goes short the supply is in protection mode, it is pointless reading voltages at this stage, check the transistor located close to the Horizontal output (Flyback) transformer and normally mounted on a large heatsink. Check the caps in the primary power supply stage....hope that helps..Phil
May 19, 2009 | Televison & Video
600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Sep 08, 2008 | Legacy Audio American Legacy II LA490 Car...
Panasonic 47" rear projection TV
If your set is still under warranty then get it fixed now other wise it will cost 300.00 or more to fix. replace nte 2973 mosfet transistor [2] capacitors 1200pf 2k volts.these caps are not hard to find look for burnted next to high voltage & convergence plugs ins.
Nov 17, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Protect LED on
this is a basic procedeur just look for any short between pins of each component.
Apr 11, 2007 | Legacy 600 WATT 2 Channel MOSFET LA470 Car...
46 people viewed this question
 Grubhead
Grubhead
