Question about World Heating & Cooling
Why does my blue flame ventless propane heater go out for no reason?
They all burn good for a day or up to a week then just start going out .first one i bought last year from lowes worked fine for two days then i came home from work and it was out and would'nt relight it was late friday so i boxed it up quick and took it back , got brand new one, hooked up worked good about 3 weeks then started going out like first one i live in south winter was about over so i just used kerosene heater when gas went out. this year i bought brand new different company (kozy world) CWD308 hooked it up worked fine for few days then started going out. 3 heaters from two different manufact. doing same thing. so i started digging in to problem what i found was when main burner kicked on the pilot would cut back like not enough pressure and come off thermocoupling then all go out. called propane supplier to check supply lines and regulator . he turned up regulator a little then heater workek fine for 4 days, on 5th night it went out ,lit right back up worked another 36hours or so then went out again, now today it will relight pilot burn good and steady but as soon as burner comes on pilot loses pressure pulls away from thermocoupling and all goes out
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Did the gas man use a manometer when the gas pressure was adjusted up? The three basic types are 1. round needle guage capable of measuring approximately 30" water column pressure, 2. U-tube manometer filled with a clear or red glycol, and 3. digital guage.
It sounds like the gas pressure is a few inches water column too high which could cause the pilot flame to actually lift off the thermocouple tip causing flame failure after the gas valve opens. More is not necessarily better when it comes to gas pressure. Normal propane manifold pressure is around 10.5" w.c. with maximum inlet pressure of 14" w.c. This pressure can be accurately measured with one of the above listed manometers by tapping into the manifold downstream of the gas valve or in the pressure tap on the downstream side of the gas valve. Most normal 100% redundant gas controls have an individual pilot adjusting screw in the valve itself for adjusting the pilot size and pressure independent of manifold pressure.
Posted on Nov 23, 2014
3 Suggested Answers
  • 75 Answers
SOURCE: pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Posted on Nov 08, 2009
  • 47 Answers
SOURCE: I just bought a brand new Kozy World blue flame
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Posted on Nov 25, 2010
Pilot light blows out while heater gets hot. Mr Heater 30000 butu ventless propane wall heater.
call a gas fitter for the repair
could be a freezing of the gas because of a blockage that is restricting gas flow
gas is not a diy repair
Dec 31, 2016 | Blue Flame Heating & Cooling
Can this unit be converted to propane and if so what is involved in the conversion
Propane is delivered at a higher pressure it is also a hotter burning fuel then natural gas. One thing you would need is a pressure regulator that would reduce the gas to city pressure which is about 1/4 psi. If you can reduce the gas to that pressure you may not need to change the orifice but you may still need to adjust the air mixture to get a blue flame. A yellow flame would indicate that it is not burning correctly and is emitting unsafe levels of not properly burned gas. That looks like a Rannai I would check with them. It also looks like a ventless, Make sure you install it more then 3 feet from an opening (windows, doors, soft vents, other vents in the house) and not under a window.
Best of Luck
Ray
Apr 28, 2014 | Rheem Rtg53xn Natural Gas Tankless Water...
Charmglow ventless gas fireplace burners won't ignite
is pilot flame on the thermopile good, pilot flame should cover the thermocouple and thermopile if unit has both
Jan 07, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Vent less gas heater wont stay burning. starts nice blue flame and than goes out no polite lite no flame.
If your heater does not stay burning then you should check each of the internal components over to ensure that they are working properly. Look at your heater's manual to do this. Failing this, the best thing to do is to buy a new one as the cost of repairing one can cost loads of money. Good luck :)
http://www.ventless-gas-heaters.com
Nov 29, 2009 | Desa International Comfort Glow Infrared...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Oct 26, 2009 | The Companion Group Kozy World Portable...
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
127 people viewed this question
Top World Heating & Cooling Experts
don-ohio
Andrew Taylor
Andrew Taylor
Are you a World Heating and Cooling Expert? Answer questions, earn points and help others
