Question about 4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck /
How can i make my transmission shift
I have replaced both shift sylanoides
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
You have no doubt eliminated wrong fluid levels as a cause since your are changing out the solenoids. I would suspect low fluid pressure either due to a failing pump or obstruction in a valve body passageway. There is a nice video on working on the pump at http://clipne.com/view/4l60e-700r4-transmission-rebuild-part-4-pump-valvebody-service-and-case-components-removal/6zXGkCCFI9UeLY8.html
Good Luck.
Posted on Nov 26, 2014
Where is the location of shift solonoid on my 99 ranger
Auto Repair: Fix Transmission Shift Problem Ford 5R55E ...
? 14:25
https://www.youtube.com/watch?v=ilYmZpgfXa8
Dec 7, 2011 - Uploaded by 1A Auto Parts
It is a good transmission but is susceptible to the valve body gasket... ... This transmission was used in Ford Aerostar, Ranger, Explorer, Thunderbird, ... Ford Explorer 5R55S Transmission Solenoid Pack Replace - Duration: ...
Replacing Solenoid Pack In E4OD Transmission - YouTube
? 12:25
https://www.youtube.com/watch?v=_CnFAcVO20E
May 15, 2013 - Uploaded by CHRIS10077
I have a really hard ( Imean HARD) shift in my 96 F-250. .... if he replaced the solenoid pack it was probably do to hard shifting ortransmission .... WHITE FACE REVERSE GLOW GAUGE INSERT INSTALL 99 - 04 Mustang ...
Transmission Shift Solenoid - YouTube
? 3:46
https://www.youtube.com/watch?v=24gkmDDV0C8
Jan 26, 2008 - Uploaded by ADPTraining
Modern transmission use a specific combination of shift solenoidON ... Vehicle Speed Sensor Location - Duration: 1:12. by richpin06a 770,125 views ... How to replace shift solenoid in 1999Chevy Blazer - Fix OBD P0758 on ...
Jan 01, 2016 | Cars & Trucks
Whhere do the wires come from to make trnsmission shift
They originate from several locations: Ground, Battery, ECM and others. A shop manual will provide the full schematic, but I located one that addresses the lockup torque converter so that you can eliimanate those wires. 25293057-xt0dpfgehhq42gmjpezjrzaz-5-0.jpg
Good Luck.
Nov 22, 2014 | 4L60E/700R4 Transmission Pan 82-97 Chevy &...
Transmission does not go into gear.
Hi, check that the cable is attached to the gear selector on the trans and does the shift quadrant move as it usually did.... not sticking or stiff in it's movement. Auto's are basically a hydraulic pump forcing oil in through valves and galleries in the valve body,,,, it could be that a gallery is blocked or that a valve has jammed shut..... check all electrical connectors for a proper fit..... do all the lights on the shift indicator light up as normal, no engine check light coming on ?
Dec 20, 2012 | 2000 Ford Taurus
Where is transmission sylanoid
All transmission solenoids are inside the transmission
Nov 08, 2012 | Cars & Trucks
How to replace a starter on a 1995 Ford Ranger Splash truck The ignition doesn't work. Just replaced the battery and the guys at the place I bought it pushed my truck in 2nd gear and I popped the clutch,...
you need to check and see if there is voltage at the sylanoid on the passenger fender the little wire marked with an S should have voltage when key is in crank potition with clutch depressed if there is voltage presant then suspect sylanoid if not check fuses and relays
Aug 14, 2009 | 1995 Ford Ranger Supercab
WHATS INVOLVED IN CHANGING A SHIFT SOLENOID AND A CONVERTER SYLANOID IN A 1997 SIERRA 4X2 CAN BE DONE EASY BY A NON TRANSMISSION SHOP A 4L60E 3SPPED OD AUTO TRANS
No that hard, but your going to have to drop the Transmission pan, there are two identical solenoid at the back of the valve body with the pan removed.
The "B" (2-3) solenoid is the closest to the passenger side,"A" (1-2) is closest the driver side.I would go ahead and replace both as they are not that expensive.Spring clips hold them in place that can be removed with a small screw driver.
The "slipping" you're noticing,is most likely just the transmission shift pattern getting screwed up due to the malfunctioning solenoid.Probably more like a 1-2-2-1 or a 4-3-3-4 pattern depending on which way the solenoid is failing,or maybe it feels like it is starting out in 2nd or 3rd gear.
Once you get the solenoid changed and transmission fluid and filer changed, here is a little added performance you can do. Have the Servos replaced with the Corvette servos, the part is only $45.00 and take about 30 min to replace but less for you since you have the truck up on a lift already.
Good Luck and here is a link for the 4L60E improvement. http://s-series.org/component/option,com_tech_article/Itemid,/item,6/task,item/
May 06, 2009 | 1997 GMC Sierra
Auto trans shifting problem
check the sensor on the transmission and give these guys a call at Schram auto and truck parts 1-800-292-1032 they sell only GM parts or try online at www.schramauto.com
May 03, 2009 | 1997 GMC Sierra
97 gmc pickup with automatic transmission trouble
1st thing to do is test the system for codes, the problem is most likely a failed or stuck shift solenoid indside the trans, have you ever serviced the trans, sometimes a fluid and filter cahnge will cure these kinds of issues.
Nov 02, 2008 | 1997 GMC Sierra
4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck / Logo
151 people viewed this question
Top Mag Hytec Vehicle Parts & Accessories Experts
Robert Rankin
ray gallant
Tom
Are you a Mag Hytec Vehicle Part and Accessory Expert? Answer questions, earn points and help others
