Question about 4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck /
Whhere do the wires come from to make trnsmission shift
I have replaced shift sylanoides
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
They originate from several locations: Ground, Battery, ECM and others. A shop manual will provide the full schematic, but I located one that addresses the lockup torque converter so that you can eliimanate those wires. whhere do the wires come from to make trnsmission  - 25293057-xt0dpfgehhq42gmjpezjrzaz-5-0.jpg
Good Luck.
Posted on Nov 26, 2014
How can i make my transmission shift
You have no doubt eliminated wrong fluid levels as a cause since your are changing out the solenoids. I would suspect low fluid pressure either due to a failing pump or obstruction in a valve body passageway. There is a nice video on working on the pump at http://clipne.com/view/4l60e-700r4-transmission-rebuild-part-4-pump-valvebody-service-and-case-components-removal/6zXGkCCFI9UeLY8.html
Good Luck.
Nov 22, 2014 | 4L60E/700R4 Transmission Pan 82-97 Chevy &...
Tranmission
my car was the same way and it turned out to be a wire with cracked insulation grounding against the transmission case. to be safe, check fluid levels and condition.
Jan 13, 2014 | 2010 Chevrolet Silverado 1500
I had to start my '87 GMC s15 truck manually- sylanoid remained open several times. when i got to my destination, my truck was completely dead. got it home due to a pull-start. thought it was just the...
First check for 12-12.6 volts at battery if you have 12 volts at battery then,check for 12 volts at starter power cable if you have 12 volts there then check for 12 volts on the switch side of starter solenoid ( purple wire ) this should get you started in the right direction.Let me know what you find out.
Apr 21, 2011 | GMC S-15 Cars & Trucks
How to replace a starter on a 1995 Ford Ranger Splash truck The ignition doesn't work. Just replaced the battery and the guys at the place I bought it pushed my truck in 2nd gear and I popped the clutch,...
you need to check and see if there is voltage at the sylanoid on the passenger fender the little wire marked with an S should have voltage when key is in crank potition with clutch depressed if there is voltage presant then suspect sylanoid if not check fuses and relays
Aug 14, 2009 | 1995 Ford Ranger Supercab
Auto trans shifting problem
check the sensor on the transmission and give these guys a call at Schram auto and truck parts 1-800-292-1032 they sell only GM parts or try online at www.schramauto.com
May 03, 2009 | 1997 GMC Sierra
Can't select 4wd low range
The jeep trnsmission should be in neutral before shifting to 4wd low.
Feb 08, 2009 | 1996 Jeep Cherokee Country
F-350 turbo-diesel hard starting
Imagine the white smoke is unburnt diesel. Anybody standing in the middle of it will be able to tell you soon enough.
Most likely culprit is that one or two of the glow plugs aren't getting hot enough. Usually just that the plugs need replacing, but worth checking first that the busbar which runs between them all is getting +12V at the appropriate stage of the process.
A.
Jul 20, 2008 | 1995 Ford F350
1998 tiburon 5 speed manuaL transmission
hey
try to use quaker state synthetic bleed multi vehicle atf
Jul 06, 2008 | Hyundai Motor 1999 Tiburon
4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck / Logo
88 people viewed this question
Top Mag Hytec Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mag Hytec Vehicle Part and Accessory Expert? Answer questions, earn points and help others
