Question about Dryers
My dryer gets hot on top and inside at the back with out being on. What is wrong?
  • 20 Answers
More then likely the element itself is shorted to ground within the housing that it is in.
For this to happen one end of the element would have to be live
with 120vac and the short will complete the circuit to creat heat.
usually the timer and motor switch will stop feed to both ends of the element but not always.
leaving the timer in a heating position,with the short will do this
if the problem is intermittent .
the motor would be the least of my suspicions
Posted on Nov 22, 2014
  • 126 Answers
SOURCE: Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Posted on Jan 08, 2009
smartr10U
  • 1305 Answers
SOURCE: Dryer will not dry clothes
Check the 4" exhaust vent and make sure that it's not blocked. If there's no flow all the heat will back up in your dryer....
A "webster" pole duster works great for cleaning the vent pipes out...
K
Posted on Jun 26, 2009
kel1guy2002
  • 3740 Answers
SOURCE: ge DRYER dpgt750EC2PL back wall of drum gets very
This may sound a bit over simplified but when a dryer starts to get hot inside it is a sign of an airflow problem.
Start with the outside vent flapper. Check to see if there is lint build up on the flapper / louvers.
Pull off the vent hose and check for lint build up. If the vent hose is a flexible plastic hose they have a tendancy to clog with lint in the sprials and then the lint contines to build up until airflow is restricted.
After checking external vents and ducts next remove the lint filter. If you use dryer sheets wash the filter with white vinegar to remove the build up. It may appear clean but the material from the dryer sheets clogs the filters.
In the area around the lint filter check the ducting / air passages for lint build up and clean it.
In the process of all the cleaning do NOT use anything sharp. A vacuum crevice tool and a Looped metal coat hanger do wonders for cleaning assistance.
Before you reconnect the dryer vent try running the dryer with a light load of anything wet to see if it drys properly with the vent disconnected. After that reconnect the vent and repeat the same drying test to see if the drying times are close to the same.
This should solve your hot dryer problem.. If it does not then respond here and we can talk about taking your dryer apart.
Thanks for using FixYa.
Kelly
the air flow out of the dryer it should be a very high volume.
Posted on Mar 15, 2010
Testimonial: "Sounds like a good idea with the vinegar. I try that first. I already checked the exhaust and it was clear. "
  • 523 Answers
SOURCE: Our dryer is very hot in the upper back and on the
clean the house vent
replace if needed
Posted on Jun 16, 2010
heatman101
  • 43501 Answers
SOURCE: my dryer is a hotpoint
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Aug 14, 2011
My Fisher&Paykel Dryer gets really hot on the top and upper left back when only running for a short period of time. what is the problem?
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 13, 2011 | Fisher and Paykel Dryers
I have a hotpoint aquarius tdc 30 conderser dryer. It gets hot and rotates the clothes, but they aren't drying. what's wrong?
Hi, Well if it is getting hot but not drying the clothes than most likely you have an airflow problem. Take off the vent hose on the back of the dryer. It will be plugged up with lint either inside that vent on the dryer or the hose will be plugged somewhere. If you clean this or just plain replace the old hose this will take care of the problem. Good Luck. feed back is appreciated.
Jan 12, 2011 | Hotpoint Dryers
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Dryer wont get hot motor runs fine
the coil has burn into, take the top and back, of the dryer, off you will see a coil spring, around, the back of the inside of the panel look for breaks.
Dec 27, 2009 | Dryers
Dryer gets too hot, so hot you cannot touch outside top of thr dryer. drum sizzle if you sprinkle water on it.
Inside back panel on the outside of the heater element enclosure there are over heat thermostats..round with two screws...
Oct 06, 2009 | GE Dryers
Why is the top of my dryer getting so hot?
Check the moisture vent for restrictions from the dryer to where it exits outside. If it is restricted dryer will overheat. Also thermostat could be faulty causing dryer to overheat. And finally the insulation might have moved out of place inside the dryer causing the top to get very hot.
Sep 24, 2009 | GE Dryers
make sure the vent is clear that runs to the outside of the house.
Jun 26, 2009 | GE DCSR483EA Electric Dryer
Dryer doesn't get hot and dry clothes
Open the door.
Remove 2 screws at the top of the door opening.
Remove the top lid, by pulling forward and off.
Look inside right and left top sides of the front panel and remove 1 screw on each side.
Remove the door.
Apr 09, 2009 | Hotpoint Dryers
Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Nov 18, 2008 | Dryers
The top of the dryer gets very hot, but inside the clothes are not drying. I have to dry the clothes 2 or3 times.regular size load. When I use cotton setting, it's worse. Water gathers along the inside of...
okay this is a easy problem, your dryer is clogged, check your vent hose and make sure it is not kinked, also check your vent duct from wall to outside...What is happening is your heat and lint is not going outside but it is going back into your dryer, causing your dryer to get extremely hot....
your dryer is suffocating
marclavoris/Whites Appliance Repair
Apr 03, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
