Question about Singer 20U109 Straight Stitch and Zig Zag Industrial Sewing Machine
How do I adjust the timing on a Singer20U109?
  • Singer Master
  • 626 Answers
TIMING ON A COMPUTER IS AN EXACT TIME THE NEEDLE, HOOK AND FEED DOG HAS GOT TO BE IN ORDER FOR STITCHES TO BE MADE. YOU NEED TO STUDY SEWING MACHINES FIRST OR SIMPLY TAKE YOUR MACHINE TO A REPAIRMAN.
Posted on Dec 13, 2014
  • 135 Answers
You can't do that yourself, you have to take to a dealer for that.
Posted on Nov 25, 2014
What does out of time mean in reference to sewing machines?
Certain things during the process of sewing must happen in a timed order for the machine to do its job, that is timing. To adjust the timing go to the link for help. How to Adjust Sewing Machine Timing
Feb 08, 2017 | Sewing Machines
Singer Quantum 5430 adjusting bobbin hook.
you cannot adjust the bobbin hook
if the timing is out , it is the needle timing that is adjusted
Jan 26, 2017 | Singer Sewing Machines
Step by step how to adjust the timing on my empisal dress maker 270D
Search the internet for:
sewing machine timing
There are multiple web sites an videos available.
Jan 03, 2017 | Sewing Machines
Adjust the timing
May I ask WHY you want to adjust the hook timing? What makes you think that you need to do so?
Oct 17, 2014 | Singer Curvy 8770 Electronic Sewing...
Singer sewing machine timing adjustment
This is an often asked question. Also, you didn't mention which model you have. Regardless, I always answer that with another question, and that is--why do you think the timing needs adjusting?
Aug 31, 2014 | Singer Sewing Machines
Singer7462 timing adjustment
try these sites
youtube
fixsewingmachine.com
Mar 04, 2012 | Singer 7462 Mechanical Sewing Machine
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
Timing the needle
That isn't the timing. If the hook is hitting the needle the hook is too far left - or close to the needle. It's adjustable by loosening the set screw at the base of the hook and by gently tapping the hook away from the needle. You want the hook to be close enough to the needle to pick up the thread loop that's formed just as the needle bar is rising.
Aug 29, 2009 | Sewing Machines
Singer 20U109 Straight Stitch and Zig Zag Industrial Sewing Machine Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
