The power comes on but when you press start nothing happens. The lights next to the buttons come on but the buttons do not do anything, like move the tone arm or start the platter spinning. HELP Me !!!!!!
If the turntable is a belt drive, most likely the belt has probably disintegrated due to ozone contamination over time and must be replaced if this is the case. Once you have the platter off you can see the spindle that drives the platter to see if it is moving.
SOURCE: TT 02 doesn't spin - Help!
i don't know if these are belt driven or not but i would check to see if the belt fell off, if motor driven then i would suspect a bad motor.
SOURCE: No control of platter speed
One of the drive circuits on the main board are faulty, and will need to be replaced. This is not an easy fix, so you will need to take it to a qualified service center for service and repair. Not an expensive fix, but a little time consuming in isolating the issue.
- TERMiNAL OPTiC
www.DJPROLAB.com
SOURCE: turntable must be started by hand
This sounds like the stepper motor that drives the turntable is failing. Are there any good DJ shops near to you?
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
SOURCE: Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
The Turntable is Driect Drive, no belt. The serial # is 1500476
