Question about Samsung CLP 300 Laser Printer
How to clean printer head
Have not tried anything yet but print from previous page is shown in a light image
    Habit-Forming:
  • 91 Answers
There is no print head in this model is a laser printer with drum
1-check toner level and the setting of toner density in setup.
2-remove toner cartridge and clean entire printer with air blower
3-replace toner cartridge
Posted on Nov 23, 2014
  • 51 Answers
Cleaning blades inside printer are likely fault. If printer has low use run off some more pages and see if issue resolves (something mechanical sticking) Else get repair. Transfer roller > transfer cart > image unit . good luck
Posted on Jun 06, 2015
4 Suggested Answers
SOURCE: samsung 2010R
turn it off, take out the cartridge and put it back in. that should do it! it helps for me
Posted on Nov 16, 2007
  • 241 Answers
SOURCE: my samsung 3175fn laser printer keeps getting a black line and ye
The printer has a build up of toner on the drum/fuser, a maintenance cleaning done by certified technician of the printer would fix this problem.
Posted on May 31, 2010
  • 10 Answers
SOURCE: samsung printer ml 1640 printing lines with the text all over pages
have your printer calibrated and have the printer heads cleaned, if this does not fix it you need to take your printer into a tech center to have a professional take a closer look
Posted on Sep 05, 2012
My Epson C86 Printer is not printing - I've tried cleaning the heads (at least 10 times) but it is still not printing. Is there anything else I can do??????
Have you tried the steps below, if not, try them Turn on the printer by pressing the"Power" button. Check the red "Ink" light next to the powerbutton. If it is flashing, you need to first replace an ink cartridge. If the"Ink" light is off, proceed with the cleaning process. 2 Open the Epson Printer Utilityprogram installed on the computer connected to the printer. In the mainmenu, click the "Head Cleaning" option. Click "Start" tobegin the cleaning process. This may take several minutes. You will hear noisesfrom the printer and the "Power" light will begin to flash. 3 Load paper into the tray when the"Power" light stops flashing and you no longer hear noises. Click the"Print Nozzle Check Pattern" option on your screen, then click"Print" on the following screen. The printer will now print a testpage. 4 Click "Finish" if thetest page looks complete. If there are gaps in the image or white lines runningacross the page, the print head needs to be cleaned again. Click the"Clean" option on the final screen instead of "Finish" toclean the heads again. Once again, the printer will print a test page whenfinished. If the page does not meet your standards, clean the head until youare satisfied.
If this does not work, try the steps below.
The fix is described here:
http://inkjetprinterhelp.us/duraink.html
But I had a few problems trying to apply it. I wound up with one of those"extra" parts. (see http://www.fixyourownprinter.com/forums/printer/37654)
So, be advised that the fix is non-trivial to perform if you're a klutz likeme, and also you probably DON'T need to disassemble the print head. (On theother hand, if you DO disassemble the print head, and you see a little partlike the one I found, please tell me where it goes!).
Regards,
Ron
Feb 14, 2011 | Epson Stylus C86 InkJet Printer
When printing a new page I get a "shadow like"
Clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Hope this helps.
Shane
Feb 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
Double imaging
hi.
1 put a small amount of light on on the bale bar (the bar the print head slides on) and then do a head clean. If this doesn't clear the problem, try doing a print head alignment, (see my previous fix) hope this helps
Apr 02, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Help!
Has it been a while since you've used the printer? If so, it's probably dried out a little. Try a couple things.
  1. Check if you are out of ink. The HP printer software will have an ink level picture indicating how much ink you have in the tanks.
  2. Print a test page.You can do this by click on the start menu, then selecting printers and faxes. Once you see your printer, right click it and choose properties. Then choose to print a test page. If that fails to print, go to step 2
  3. Clean the print heads. In the previous menu, you should find an advanced button. You'll have to search around a little as I don't have this printer, but there will be an option to clean the print heads. You may have to repeat the cleaning multiple times before you start to see an image.
If that doesn't work, comment back and we'll try some other things.
Steven
Sep 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Samsung CLP 300 Laser Printer Logo
289 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
