I want to reset my washer model#WA422PRHDWR/AA
  • 46 Answers
Make sure you turn the machine of then unplug it from the wall socket wait a few seconds the plug it back in fill it with washing put powder in, turn nob to the wash you want then press start. hope that helps.
Posted on Nov 23, 2014
  • araceli Nov 23, 2014
    No dint help,still the same door nop doesn't look,,so posses can start.
    No dint help,still the same door nop doesn't lock ,,so posses can start.
My Samsung washer model WA456DRHDWR/AA doesn't have any power. Need help troubleshooting.
Hey Cindy,
First, makes sure all the breakers have been reset and do not trip when you try to use the washer.. if the breaker trips each time you try to use the washer, then you need to cal a qualified repairman..If the breaker is good and stays on, make sure its plugged in correctly..if its plugged in and you have power at the plug..( are you mechanically inclined?).. if not call the Qualified repairman)..there are several things that will cause it not to work,,
Samsung WA456DRHDWR AA User Manual Check These Solutions If Your Washer...
http://www.appliancepartspros.com/repair-help/samsung-washer-wa456drhdwr-aa-0001-repair
check this out..
Samsung Recalls Top Load Washing Machines Due to Risk of Impact Injuries
Sep 11, 2017 | Samsung Washing Machines
Washer fills with water during spin cycle
Go to repairclinic.com and have model number ready. They have videos how to check it
Mar 02, 2015 | Samsung WA422PRHDWR 4.2 cu. ft Large...
Samsung HE Top Load washer always going off balance. Only 4 months old and Ive had trouble since day 1.
Open this link and chat with Samsung technician .
('http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000651&model_name=WA45H7000AW/A2&model_cd=WA45H7000AW/A2','',800,600)
Jan 04, 2015 | Samsung WA422PRHDWR Top Load Washer...
Cannot remove the dispenser tray
There should be a little piece you push down, when you pull it out till it stops, look at the top back of the dispenser it should look like a key on a piano but the same colour. Press down and pull.
Jun 16, 2014 | Samsung WA422PRHDWR/AA 4.8 cu ft ENERGY...
Samsung WA422PRHDWR/AA not draining
i had a the same issue and my fix ended up being the leveling sensor. repair man said if you tilt your washer to far in any direction it throws it off...hmmm
Dec 27, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
