Question about Health & Beauty
I hv a battry operated tooth brush. will not run with new batteries. What cld be the problem?
I hv used new batteries but nopower
  • 3,368 Answers
You probably have them in wrong or there is a bad connection.
Posted on Nov 27, 2014
Why doesn't work
TRY CLEANING YOUR BATTERY CONTACTS AND PUT IN NEW BATTERIES.SOMETIMES THE BATTERY CONTACTS GET DIRT ON THEM.TAKE A OLD TOOTH BRUSH AND GENTLY BRUSH OVER THE CONTACTS.
Aug 13, 2014 | Radio Communications
What controls the cooling fan on my 86 grand national?
shld be/cld be any one of 3 veh shld hv temp sensor,cooling fan switch both located in the block one shld be in the intake or thermostat housing, one in side of block, ahd relay cld be near wiper motor, or under dash in the conenience center, may be above hood release latch below light switch
Aug 26, 2012 | Cars & Trucks
Battery terminal corrosion
Clean it. Unscrew both postive/ negative terminals. Use a tooth brush or soft wool, or maybe some high grit sandpaper and brush against the corrosion and clean it throurly, and reinstall the clamp back to the terminals. Eventually your battery may need replacement on the long run, since it's building up major acid corrosion.
Jan 13, 2011 | 2004 Honda Pilot
I replaced the battry in my laptop and now the charge light does not go off even when it says its full it keeps trying to charge.what is wrong?
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 29, 2010 | Computers & Internet
Battry bacak problam .
Sep 08, 2010 | Lenovo 3000 Y410 Notebook
My lenevo y410 laptop power line is ok but battry is do not work.plese reply as soon
Aug 20, 2010 | Computers & Internet
Battery light comes on
the battery light coming on may indicate that the alternator is not charging,it should come on when the ignition is switched on & go off when the engine is running, you need to check if the battery is being charged or not......hope this helps.....cheers
Aug 02, 2010 | 1997 Ford Explorer AWD
My silcon 40kw was not run on batries battries are new and its battry fuse are also good
please clarify your problem. is the ups on? does it report any alarm? to see this alarms press * , then scroll down using the keypad button that has an arrow in it. if there is no battery weak alarm, press the enter key. does the display read 'normal operation' and does is show load percentage? if so press # the scroll through using arrow keys untill you get 'battery capacity test' , press c then # , this should start a battery capacity test, press battery voltage key. if the batteries are okey the voltages should read 400 then they continue to drop gradually. to revert to normal operation press # then c then # this should bring back the ups to normal operation
Dec 20, 2009 | APC Silcon UPS System
Fuji digital camera
I think I've solved the same problem on a Finepix A350. My shutter has been sticking for months now on powerup. I brushed all round the periphery of the shutter with a perfectly clean, small, camel hair brush and now it operates perfectly! So maybe the answer is to keep a new brush specially for this. Hope this works for you! I certainly would not try dropping the camera as someone suggested.
Jul 16, 2008 | Fuji FinePix A345 Digital Camera
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
