Question about Video Game Consoles & Games
I was listening to music and suddenly my KLH sub stopped working. I unplugged it and plugged it back in, but it still won't work.
Unplugging and plugging back in
  • 36 Answers
You may have blown the speaker. Bring it to wherever you bought it from and they can see if you did or not.
Posted on Dec 12, 2014
Big Hev
  • 64 Answers
SOURCE: PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
Posted on May 19, 2009
  • 273 Answers
SOURCE: wont read any disks for PS#
have you tried cleaning the lens with a laser lens cleaner?
Posted on Jun 11, 2009
SOURCE: Wii Console stopped working
I unplugged the Wii system for about 15 min then turned it on and it works fine
Posted on Jun 17, 2009
SOURCE: wii is suddenly only playing in black & white.
From the Wii, the Audio-Video (AV) cable is Red White and Yellow. Now, those R, W, Y should connect to the R, W, Y inputs of your TV. At times, the inputs to the TV have a Red, Blue, Green input - DO NOT USE those inputs. This is precisely what happened in my case. Now, it is fixed.
Posted on Dec 05, 2009
colbary77
  • 102 Answers
SOURCE: wii stopped working...unplugged it and plugged
you will need to unplug from the wall and unplug all cables from the Wii.
After this you need to hold the power button in for 30 seconds while its unpluged to discharge it.
Posted on Jul 02, 2011
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
Apr 26, 2014 | Harman Kardon AVR 7000
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
The subwoofer SP-PWM505 won't turn on.
Make sure its not set to Auto. Also check for a fuse in the back. Unplug the amp side and with the sub plugged in touch the RCA. You should hear noise from sub. Try this last. Some may say this is not good for the sub. Im in the business and never have seen it cause a problem
Jun 18, 2013 | JVC SP-PW100 Subwoofer
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Constant sound from subs
I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
Jan 09, 2009 | MTX RT2200 Car Audio Amplifier
No sound...
you have wires grounding out at the back of the unit. i suggest trying to completely rewire it and see how that works. its easy if youve never done an install so dont sweat it. email me if you have any questions.
wellgood04@yahoo.com
May 13, 2008 | Panasonic CQ-C7301U CD Player
Cadence z1200 stays in Safe Mode!
If the subs are rmoved from the amp (wiring), does the amp still go into protection without them hooked up? If no, shorted sub, if it still des, unplug RCA's, does it still go into protection? Also check voltage. Make SURE you have greater than 12 volts AT THE AMP using amps ground to check the power AND remote wires. Hit me back wth an update.Those amps rock.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Sep 17, 2006 | Cadence Z8000 Car Audio Amplifier
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
