Question about Cell Phones
My charging port is malfunctioning so i charged my battery in my phone with the charger connected straight to the battery. Now my Samsung galaxy s 4 phone won't turn on. What can i do?
  • 4 Answers
I had the same phone. My port was the problem and I battled U.S Cellular telling them this phone is a lemon and they need to do something about it. I ended up getting the Galaxy S 4 Mini. It is much much better. I would bring it to your carrier right away and tell them what happened. That the ports in this particular model are faulty not the users of the phone. And see what they can do for you. If you do not have a carrier where you can have them see then I recommend buying another battery and a battery charger to plug into the wall along w/ the battery. Amazon.com has great deals on them. I hope this helps and good luck.
Posted on Nov 22, 2014
SOURCE: Samsung t509 won't charge
would something like this work?
http://www.bayho.com/p/PCMB-DC-KE850.html
Posted on Jun 04, 2008
timthorne911
  • 464 Answers
SOURCE: Internal charge port is bent
No, you need to take it to a tech, or get a replacement phone. Kinda sucks, but that's the only way to do it. If you have insurance you may be in luck to get a replacement for free.
Posted on Mar 18, 2009
SOURCE: Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Posted on May 25, 2010
  • 70 Answers
SOURCE: my samsung rant wont charge
you can see if ebay have a broken phone like yours and you can use the parts off the phone you buy from ebay to replace the one in your phone.
Posted on Oct 28, 2010
Geekman
  • 32281 Answers
SOURCE: my samsung galaxy pro GT-B7510 battery Not getting charged by Charger and only by USB cable and power lossing immediately i remove cable, how can i solve ??
Check the mains power adapter with a multimeter. Plug the adapter into the wall mains socket and then measure the voltage on the adapter plug, the voltage should be slightly higher than the voltage that is printed on the adapter. If you get a low reading or zero reading the the charging adapter is faulty and needs to be replaced.
Posted on Mar 30, 2012
It charges somtmes but only 26% now it wont charge and wont turn on i have changed cords and plugs nothing works please help
1. is there lint or some pants pocket debris or dirt inside the charging port on the bottom of the phone? use something non metal that won't break inside, it needs to be thin enough to move around and poke around the bottom, not interfering with the chip that sticks out.
charges-somtmes-but-only-26-now-wont-c42sdu52tip34gjoftdmfcql-4-0.png before you do that.. turn off the phone and take out the battery just in case. you don't want to short the charging port, so why risk it.
you can use a thin side wooden tooth pick (not the thick rounded ones, they won't fit), or you can use an unused plastic brush tooth pick that's available at most stores like Walgreens, CVS, Safeway, etc..
2. If nothing comes out, try using a different wall charger adapter that works for your Samsung device. Many cell phones use a 3volt charger that won't work with Samsung smartphones because Galaxy phones need a 5volt charger. The others will just trickle charge it or may not work at all. Also, the cord itself. You can't just use any micro USB charging cable. You need to use one that can push enough electricity to your device. So it has to be a Samsung smartphone compatible one. If you have ruled this out..
3. Is the wall outlet bad? Try a different wall outlet. Example: at the airport we tried all the wall outlets in the same area, none of those charged the device. We thought it could be the charging cable or the adapter that was dead. Then we went to another area in the airport and tried again. This time we were charging the phone fine. Cable and charging adapter were apparently working great.
4. If that's not it.. what happens when you try jiggling the charging cable connected to the phone.. try angling the cable head to the left or right.. does it only charge when in a specific position? it could be the charging cable or the charging port that needs fixing..
5. If that was not the case, and everything you've tried doesn't work, it could just be the charging port on the phone is bad. Bring it to your local cellular repair shop. It should cost around $35 to $50 to fix.
6. If your phone is not worth it to fix it, it might be a better idea to buy a newer model phone. If you can't afford another phone or to fix the port, why not just buy a separate battery wall charger. You can buy a cheap China version to charge your existing battery outside of the phone and then just pop the fully charged battery in when you need to use the phone. I'd recommend charging the battery when you are sleeping.
The attached link is to an eBay listing that has a compatible wall charger sold in the US for $5.99 shipped free
LCD Battery Charger for Samsung Galaxy Mini GT S5570 i5510 S7230 S5330...
Nov 10, 2015 | Samsung Galaxy GT-S5570
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
Samsung galaxy s2 not charging
Either your battery needs to be replaced or charging port is damaged
Jan 14, 2013 | Cell Phones
Galaxy Note slow charge. Holds battery well though.
try this ..get a qtip and dip in 99% rubbing alcohol. not too wet. just damp. clean contacts on the charger port. use a magnifying glass and light to check if its clean. let it dry for 20 mins. it will also help if you have airplane mode on but its optional. use oem charger and cable or ipad charger works fine with samsung cable. hope it helps
Jun 10, 2017 | Samsung SGH-i717 Galaxy Note HD LTE 16GB...
Galaxy tab p1010 not charging
Hi!Maybe this will work:1. Try a different charger.2. Connect it to a pc to see if that can charge your tablet (if this is working, it means that your charger is the problem)3. If none of the above works, then is the battery or the device itself that don't function properly and you should go to check it on a autorized service shop.
Hope this will help you!
Have a nice day!
Sep 28, 2011 | Samsung Galaxy Tab Tablet PC
My e900 wont turn on or charge
most likely your charger port is damaged, if you try another charger and get the same thing- then I am sorry but the phone is finished. warranty does not cover damaged ports, but if you have the insurance it is covered under damage, if its lless than a 30 day old problem. If you replace it with the same phone, discard any chargers you used on the old one.
Aug 18, 2009 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
