Question about Kitchen Appliances - Others
How do I find insert replacement for my Crofton Turkey Roaster Oven
Need replacement insert
    Problem Solver:
  • 10 Answers
There should be a model and serial number somewhere on the unit. if you lost the owners manual you can go online to various supply house that carry your parts. Just type in Crofton Turkey Roaster Oven Model #....... and search for your part.
Posted on Nov 27, 2014
Can I purchase a replacement lid for a crofton roaster oven
you can certainly ask the manufacturer thru their website .
Oct 17, 2015 | Kitchen Appliances - Others
How to roast a turkey in 18-quart Rival Roaster Oven. Need full instructions for 14 pound turkey. Have lost manual!
Hello Carolyn,
Here's a link to the Rival web site and your instruction manual for the 18 quart Rival Roaster. Basically you set the roaster to 350 (fresh) or 375 (pre-basted frozen and thawed) degrees and cook the Turkey for 9-14 minutes per pound of the turkey. Use a meat thermometer and cook until the Turkey reaches 180 degrees.
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
I would download and print out a copy of the manual for your use and reference. I also save an electronic copy of all the instructions and owner's manuals on my computer in a file I've titled "Household Items - Manuals & Guides". This makes it easy to retrieve them in the case I lose them again, as they might not always be available on the internet forever.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Water in bottom
Download manual here: http://www.rivalproducts.com/search?q=rival%20manual%20roaster
Page 4:
NOTE: Never place food or liquid directly into the ROASTER OVEN BODY
Nov 28, 2009 | Rival 18 Qt Roaster Oven with Buffet...
When roasting a turkey, do you use the insert or does the turkey go right in the oven
You definitely use the insert. Rival does not recommend using the roaster without the insert.
Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
I do not have the book and need to know if I am supposed to pour liquid in the bottom of the roaster when I start the turkey.
No, you never put water between the roaster and the cooking pan/ cookwell/ insert, it actually interferes with the cooking. You can put a little water in the bottom right under the turkey, but the roaster cooks very moist and this is really not necessary.
Check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Do you have to put water in the first pan to cook a turkey?
Absolutely not. This is an oven, not a steam table, and water in the main roaster actually interferes with heat transfer. Water in the roaster cooking pan (the inside pan) actually steams the turkey, not a yummy solution.
Nov 21, 2009 | Rival 18 Qt Roaster Oven with Buffet...
My 22 lb turkey isn't going to work in my Hamilton Beach roaster using the insert pan. I probably can't take it out and just cook in the bottom part, huh?
I never tried it with mine, bit the lower part is waterproof and the same material as the pan, so I would say you probably could, however, since they heat from the sides try to make sure the turkey isn't touching the sides directly or it may burn.
Nov 20, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Big 18 pound turkey and no manual
Place turkey on trivit in roaster and add 2 cups oof water. place lid on roaster and seal edge with foil. Preheat oven to 500 degrees.  Place in oven for one hour and turn oven off and go to bed.  Turkey will cook while temperature is coasting down.  Turkey will be still warm in the morning.  We have been doing this for several years and always comes out golden brown and juicey.  Do not stuff bird while cooking.
Nov 30, 2008 | Rival 18 Qt Roaster Oven with Buffet...
Placement of water in the roaster
Hi Joan,
To prepare a turkey, I first spray the liner and grate with Pam. Then prepare your turkey as usual. I do not salt the turkey as I found out the hard way that it make the juices too salty. Instead, I stuff, then butter the outside of my turkey. You should have the liner inside the roaster, with the grate on top. Put your turkey on the grate, add a can of chicken broth. Cook per instructions. I have found out that the tukey will be done quicker then it states in the instructions. If this happens, just keep the turkey warm in the roaster. Good luck.
Nov 18, 2008 | Rival 18 Qt Roaster Oven with Buffet...
No conventional oven...will turkey brown in roaster oven?
it looks like we're looking for a solution to the same problem. i've been searching and searching for an answer but have only found a few choices. one is to take the turkey out during the last half hour of cooking and place it in the oven to finish, thus browning the outer layer. another says to put some kind of a rub solution on. the solution is made up of sauces or juices that i really don't want in the flavoring of my bird. i wonder if the lid on the roaster was to be situated a little higher over the roaster so that the moisture could escape but heat could still be captured an reflect back toward the bird thus allowing the skin layer of the bird to "dry out" and bake. i haven't figured it all out. i'm still looking.
Nov 11, 2008 | Rival 18 Qt Roaster Oven with Buffet...
Kitchen Appliances - Others Logo
703 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
