Thermoheat forced air heater hard to start after sitting overnight or for extended time. It blows diesel out pressure is 3.5 everything turns on just won't ignite. after turning it off an on several t
I have cleaned big filter, I have cleaned the igniter and thermocell eye.
  • James
    James Dec 03, 2014
    I have cleaned ALL filters the manual says 3.5 on pressure but I have tried to adjust the pressure but it will not adjust I screww the screw all the way in or out no difference. I have good spark an fuel spraying out but it doesn't ignite.
  • James
    James Dec 03, 2014
    I say no difference I mean the pressure doesn't change. Not only did I clean filters I even removed them just to see if thT helped
    Scholar:
  • 146 Answers
The pressure should be higher than 3.5 psi.
You have an output filter under the rear plastic cover that is held on with the 4 screws.
Check that filter to see if it is dirty.
The PSI for the heater should be on the side of the heater.
Posted on Dec 03, 2014
4 Suggested Answers
mandm7537
SOURCE: RM115 Reddy Heater forced air heater problem
I had close to the same problem i drain the tank added new fuel still no diffrence so i removed the filter going to the tank pick up flushed out with brake clean it work fine for half a day . I knew then i was on the right track . I went to the local hardware store and bought a tune up kit that had the filter in it,I replaced the filter going to the tank pick up and it's been working fine even in cold weather. Fuel quality has a big part to play in it's abbility to burn in colder tempicures.
Posted on Jan 16, 2009
  • 58 Answers
SOURCE: goodman heater not igniting, light blinks once
LAST RESORT IS THE BOARD, FIRST I WOULD TRY THE VACUM SWITCH TO SEE IF THAT IS WORKING, IT IS THE ROUND PEICE WITH A HOSE GOING TO IT, MAKE SURE IT IS NOT BLOCKED, YOU CAN BYPASS IT BY CONNECTING THE TWO WIRES TO IT, STICK A PAPER CLIP IN THE ENDS OF THE WIRE CONNECTORS, TRY IF THAT DONT WORK, CHECK THE LITTLE ROUND DISK THAT ARE LOCATED ON ALL SIDES, THESE ARE A SAFETY FETURE, THEY USALLY HAVE A LITTLE BOTTON ON THEM, JUST LITELY TAP THEM, TRY. MY GUT TELLS ME IT IS THE GAS CONTROL VALVE, FAN STARTS, IGNITOR STARTS, NO FUEL, THE GAS CONTROL VALVE CAN BE CHECKED WITH A VOLT METER, WHEN THE UNIT GOES THRU THE START SEQUENCE, THE TWO WIRES GOING TO THE GAS CONTEROL VALVE SHOULD HAVE 24 VOLTS OR ABOUT GOING THRU THEM IF SO VALVE IS BAD, USALLY IF IT IS THE M.BOARD YOU CAN LOOK ON THE BACKSIDE OF THE BOARD AND YOU WILL SEE EVIDENCE OF FAILURE,A BURN MARK, I HOPE THIS HELPS.
Posted on Jan 20, 2010
mxc2
  • 146 Answers
SOURCE: r100 reddy heater, low pressure forced air heater.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Posted on Oct 22, 2010
Testimonial: "thanks! it is the kerosene heater. i ordered the low pressure gauge and will check pressure. motor cuts out and you hear the safety switch click."
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
1989 f-250 starting issues
Is it diesel and what color is the smoke (white or black)?
Nov 04, 2012 | Cars & Trucks
What is a glow plug
Glow plugs are heating devices to aid starting diesel vehicles.
Purpose:Diesel engines, unlike petrol engines, do not use spark plugs to induce combustion. Instead, they rely solely on compression to raise the temperature of the air to a point where the diesel will combust spontaneously when introduced to the hot high pressure air. The high pressure and spray pattern of the diesel ensures a controlled, complete burn. The piston rises, compressing the air in the cylinder; this causes the air's temperature to rise. By the time the piston reaches the top of its travel path, the temperature in the cylinder is very high. The fuel mist is then sprayed into the cylinder; it instantly combusts, forcing the piston downwards, thus generating power. The pressure required to heat the air to that temperature, however, necessitates the use of a large and very strong engine block. The problem posed is that in cold weather, if the engine has not been running (as is the case when the car is left to sit overnight), that the large engine block becomes very cold; when one then attempts to start the engine, the cold engine block acts as a heat sink, quickly dissipating the heat generated by the pistons compressing air. The engine is then unable to start, because it cannot generate and maintain enough heat for the fuel to ignite. For that reason indirect injected diesel engines are manufactured with glow-plugs in each prechamber, and direct injected diesel engines are manufactured with glow-plugs in each combustion chamber.
Wikipedia
Dec 07, 2011 | Cars & Trucks
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
HARD START AND BLOWING SMOKE
clean all of your filters and the spark plug and go back to useing K1 kerosene. Diesel fuel has a higher ignition temp. burns dirty and has a tendency to gel.
Jan 20, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
