Question about Maytag Neptune MAH5500B Front Load Washer
NO water temperature difference with any button (Hot, cold, warm)selected.
Also shuts off at first, second and third rinse cycle; have to manually restart the machine with the round "start" button.
    Problem Solver:
  • 11 Answers
Could be the screens in the hoses at the wall hook ups are plugged or restricted. Check them first.
Posted on Nov 22, 2014
  • Jay Scruggs
    Jay Scruggs Nov 22, 2014
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What us your model number?
catriver
  • 878 Answers
SOURCE: Water temperature problem
Chief Walley, you have a temperature control board that sits right behind the timer. A thermistor senses the water and sends the info to this board. The thermistor sits at the water injector. The board may be your problem, I have seen many like this. Keep in mind that the target temp for cold is 75 degrees. If your incomming water is higher than this, you are going to get a warm fill, which they think is cold. Without being there, I would go after the board. Catriver...post back.
Posted on Aug 09, 2006
  • 79 Answers
SOURCE: maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Posted on Jul 05, 2008
jsrock516
  • 5911 Answers
SOURCE: water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Posted on Aug 26, 2008
suben
  • 214 Answers
SOURCE: My Maytag washer is overflowing
the inlet valve has to be checked or replaced if required
Posted on Sep 09, 2008
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
My washing machine mentioned above wont drain the water or preform the spin cycle process once it gets to the usual 7 minute mark. No leakage, just not drain or spin. How can I fix it?
TIMER
Mar 26, 2015 | Washing Machines
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
Mar 17, 2011 | Washing Machines
Hot water seems to not enter tub during washing cycle. all connections are correct and the hot water hose is hot up to the back of the washer, im baffled ? does the unit start with cold water on the first...
They start with hot or warm ,what/ever the setting and rinse with cold water. Check the temperature adjustment and the cycle it's on as some do different things on different cycles.
Dec 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
