Question about Vizio M422I-B1 42IN LED LCD Smart TV Full Arr
I have a 42 in vizio that when power up the light come on n go off 3 to 5 sec later. i do not have a remort for it.
Replace t con board n supply board
    Top Expert:
  • Vizio Master
  • 75,462 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 22, 2014
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Posted on Apr 25, 2013
SOURCE: Power Supply Board
http://www.encompassparts.com/products/?VIZ0500-0502-0102
This is the only place I founf that carries the
part.
Posted on Jan 05, 2009
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
SOURCE: Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Posted on Oct 21, 2010
My Vizio m420nv tv the left half of the screen has a yellow tint throught the whole screen. the right hand side is fine. Ive changed the T Con Board and didn't change anything. any ideas?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 01, 2015 | Vizio m420nv 42 in. LCD HDTV
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
My Vizio E420VL would not power on.
It is possible you have a faulty main board. The main board is in charge of sending a signal to the power supply to "turn" on the set. So assuming your replacement power supply is a working board, I'd lean towards the main board. I would recommend getting a professional diagnoses to be sure.
Nov 24, 2012 | Vizio E420VL 42 in. HD-Ready LCD TV
Vizio m420nv has sound but no picture
Hello there
Actually that problem is very common on all LCD TV,, that problem is cause of either inverter board or t-con..
In this case you don't need to check the voltage that is too complicated for you,,only visual check is enough..
I share you my tricks and hope it helps..
Power on your TV turn off your lights..if you will see the light comes from the screen the problem is t-con..if no light the problem is inverter board (backlight) board
Hope it helps..
Don't forget to rate..
Aug 25, 2012 | Vizio m420nv 42 in. LCD HDTV
Green light turns but tv wont turn on
if you have sounds and backlight replace t-con board..if no backlight but have sounds inverter board..
if no sounds or backlight try this...
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 25, 2012 | Vizio E420VA 42 in. LCD HDTV
Vizio E422VA 42 in LCD television power light blinks
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
Mar 04, 2012 | Vizio GV42L 42 in. LCD Television
I have a Vizio 50"
Good day!!!
That problem is usually cause of bad inverter board or T-con board also there is the possibility that you have failing capacitors....
If your TV is totally black even back-light the problem is inverter board..please try to replace it to fix your TV.
If your have back-light but no image comes out...The problem could be on the T-con board..if that so please replace it...
This is for bad capacitors...
5. Some of the capacitors not bulged so its better if have a capacitance meter..
Look at the label capacitors...That is the sample image..
I hope this solution will be helpful...Thanks for using fixya...
Aug 17, 2011 | Vizio VX42L 42 in. LCD TV
Apr 09, 2010 | Vizio VX42L 42 in. LCD TV
Vizio M422I-B1 42IN LED LCD Smart TV Full Arr Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
