Question about Bose Audio Players & Recorders
Bose Media Center AV321 humming on all channels.If I send this for servicing will it cost me as much as getting another reciever
All trouble shooting from maual
    Top Expert:
  • Bose Master
  • 74,185 Answers
No. The audio output section circuit only have to troubleshootet. Electro help
Posted on Nov 22, 2014
5 Suggested Answers
SOURCE: the bose av321 disk door wont open
Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center
Posted on Apr 02, 2009
pctech1
  • 1940 Answers
SOURCE: The bose AV38 media center
System does not function at all:
  • Make sure all power connectors, cords and plugs are inserted securely and that the outlets are in good working order
  • Be sure to select an audio source (CD, AM/FM, etc.)
  • For powered systems, unplug the power pack for a few seconds, and then reconnect it. This allows the unit to reset itself after a power surge or power interruption.
No sound:
  • Increase the volume.
  • Press the MUTE button on your music centre or remote control to unmute the sound.
  • Check the connections to any external components.
  • Be sure to select the correct source (CD, AM/FM, etc.) for the desired input.
  • Unplug the system's power pack for a few seconds, and then reconnect it. This allows the unit to reset itself after a power surge or power interruption.
  • Check the speaker and ACOUSTIMASS® module (if applicable) connections.
  • Disconnect any headphones.
  • Connect the FM and AM antennas, if applicable.
Sound is distorted:
  • Make sure the speaker cables are not damaged and the connections are secure.
  • Reduce the output level from any external components connected to the receiver or LIFESTYLE® music centre or CD changer.
Posted on Jan 25, 2011
SOURCE: How to open Bose LS12 series II music center to trouble shoot
the black box has a plastic lever on top, turn it with a thin screwdriver, then pull the plastic cover, if the black box has 2 screw on botton apart them.-
Posted on Jun 03, 2012
hayki2000
SOURCE: bose av28 access menu using control buttons
problem solved, it turned ou that the problem was actually the remote, but service center tried newer remote control models for replacement and the unit did not respond till they finally tested with same version remote.
Posted on Jan 01, 2013
No sound from bose 321
You need to localize. Play a DVD, does the same audio cutout happen? Do you have the center dvd or the left mounted dvd? The console unit has input jacks for external audio inputs, put an external audio source in and see if the same cutout occurs. See if the external output jacks lose audio or just the system speakers, including subwoofer. This may help localize which unit has the problem.
Is the console stacked above or below other electronic units, it may be a heat related cutout? Reseat all your interconnect cords, I have seen corrosion occur on the square connectors.
These are expensive to have repaired, good luck. If you're daring enough, you make find free service manuals on websites like Elektrotanya, hifimanuals, hifiengine, and eserviceinfo (.com)
Jul 15, 2016 | Bose Av3-2-1 Series Ii Media Center...
Playing fine but when is off is still plying
Control buttons on the Media Center may need to be replace by a Bose service Technician.
Sep 26, 2015 | Bose Av3-2-1 Series Ii Media Center...
Cd/dvd unsupported
The "format unsupported" message is cause either by a scratched CD/DVD or a dirty optical lens.If the lens is bad,then the DVD ROM will have to be replaced by a qualified service personel.
Mar 22, 2014 | Bose Av3-2-1 Series Ii Media Center...
Bose av321 video settings won't display on tv
Make sure the video output from your Bose System is connected to the right input source of your tv.If it does not work,try using a different remote control.If it still doesn't work,then you will need the service a Bose repair technician.
Jan 28, 2013 | Bose Av3-2-1 Series Ii Media Center...
Disc tray will not open?
There could be a disc jammed in the tray. The humming sound is the tray open/close motor trying to work
Jan 16, 2013 | Bose Av3-2-1 Series Ii Media Center...
May 12, 2012 | Bose Lifestyle 12 System
The bose av321 disk door wont open
Follow these steps:
Mar 28, 2009 | Bose 3 2 1 GSX System
70 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
